Thread title fail.
lol it was a topic title to draw attention and it worked :D
anyway, does anyone think that hard wiring the fuel pump will fix my 300rpm lumpy idle. and the miss on throttle application?? i was just going to do some basic patch wiring over the fuel pump relay into a second relay but i cant find one in the fuse/relay panel :/ am i going nuts??
Edited by lilcrash
  • Replies 47
Except now you've lied to everyone else.
And I don't like being lied to. Especially about people lying.
Don't lie, you love being lied to, it's being lied on that you don't like!nyaanyaa.gif
yes theres alot of BS surrounding the fitment of walbro pumps. so many ppl say "they bolt straight in" on so many cars. they just forget to mention that the plugs need to be changed and you have to modify mounting brackets and hold the whole thing together with zip ties. after all the shit i want through with my commodore i'll never touch another walbro pump again. OEM branded pumps are a much better way to go.
There's nothing wrong with "real" Walbro's, the fakes gave them a bad name I guess, but that's the way every brand is these days. My twins are quiet and flow massive amounts of e85 right up to 80psi with little effort. For the price they cant be beaten and low current flow makes them easy on your wiring but they definitely need full 14v straight from the battery. Just wire the old power feed up to a 30amp relay that switches the 14v if you haven't already.
I used a hose clamp to hold them in place.
For the M35 guys Walbro's drop straight in to the stock fuel housing once the tabs on the top are trimmed off.
No, there is a fuel controller that gets a signal from the ecu.
The wire that went to the stock pump you use to energise a new relay that switches the 14v straight from the battery, (through a fuse of course). That way the car is still controlling the on and off of the pump just not dropping the voltage at idle which is your issue I think.
Could your fuelling issues be that the cradle didn't clip back correctly into the tank, and has now come loose?
I know I almost didn't clip mine back in properly when I fitted my Walbro pump (18 months ago and running just perfect still).
:thumbsup:
I think the biggest problem with stagea fuel pump upgrading is everyone goes into the job expecting a cradle like the skylines and it's not, it's a holder/box on the bottom of the tank.
I know i did, and I was like WTF when I opened the tank and there was no lift out cradle. it also took me a little while to figure out how to get the top of the holder to get to the fuel pump, didn't help that my tank was about a 3rd full.
Also to anyone that said walbro are too much of a stuff around to fit you obviously haven't trying to fit one to a S2 stagea before. If I laid a stock pump next to a GSS-342 you would hardley notice a difference. Inlet/outlet sizes are the same, electrics are the same, physical size is the same.
Steven, if you have a nistuned ecu that already has the Z32 afm swap done on it, and you swap your afm to the Z32 and use that ecu it should start and run. It wont be perfect but enough to know that it works. Nistune does a good job at resizing the values on afm swaps. When I did mine it was a little bit out, it was rich, I had to drop the kconst a little bit to get it running stoich. Unless you have a wideband to check it I wouldn't drive it around.
HA!!
you guys think YOU dont like being lied to....!
How about this then; Surgeon - "I'll remove your kneecaps & you'll be fine."
4 years later; loss of job/house/marriage & throw in same-old chronic disabling pain for the fun of it.
f**king KUNT of a surgeon. Pity I had no other option though, as the pain from bone on bone for 15yrs in both knees was pretty intense, so much so I just had to agree to removing the patellas & 'see what happens'.
IN or OUT its the same deal. Just now Im disabled in my movement, etc.
lol, rant over.
Anyways, I bought a Walbro 'da-27' 305LPH fuel pump, installed externally (GTR intank pump feeds 5L surgetank, walbro then feeds 550cc injectors).
From what I can tell its a bosch 044 copy and isnt walbro at all. Made by Driven2Automotive but marketed as Walbro.
Ive been lied to!
I'm doing the hard wire mod as I type this, hopefully it will sort it out.
Xrated - that's a bit harsh to say letting my wife do it was a mistake, she has smaller hands and she has learnt a helll of a lot over the years. Let's see things she has done while I was at work, built a diff from 3 broken ones, 3 turbo swaps, 2 engine removals and 1 gearbox swap. And she wants to go do an auto ellecy apprentice ship so she can do ecu installs and tunes.
this is exactly my point. the pumps work great. but theres nothing "bolt in" about them. having to wire up a new relay and custom mounting makes it difficult for ppl without the tools or experience. my advise to anyone with little experience is do not attempt it.
Here a how to with some pictures which may help:
http://www.skylineow...d.php?p=1492788
(As a matter of interest I think it was written by the guy who expressed an interest in bringing his (masa fronted) stagea to Aus)
Indeed it was me that wrote that guide.
Fitting was exactly as per the guide, my Stagea is a Series 2 RS4V and I did also do the earth mod and run another better supply via relay too. I think that any uprated pump would require better wiring, the standard wire gauge in the car isn't exactly generous.
Oh and I'm still waiting for the job. The recruitment is on hold at the moment, but rest assured if I get the chance to transfer I'll be coming to annoy some of you guys in person ;)
Edited by DeanR33
Does she have a sister? :worship:
I think you're very lucky to have such a wife! Apart from the practical advantages its great to have a partner who shares an interest in car engineering :) :) :)
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
