Meh. R35 is a great car. When I had mine I got plenty of unwanted attention at servos etc but this was 08-09 before the aus models were released. Its fast as he'll but has no where near the drama of even a gallardo (Audi or not their v10 sounds pretty nice). To be honest I'd be just as happy in and old countach (yes I have an 80s coke dealer complex and I also like linen suits), or give me a fcking diablo. That is a super car. I've drive the new gt40 snowy was talking about. Awesome looks, awesome sound but to me it felt a bit sloppy and boat like. Definitely a super car though. I still reckon an old diablo gets more looks than a r35 but who cares? If getting people to look at you is your thing just run around naked... Otherwise buy whatever car YOU like. Personally I want an f40 a diablo, a countach, a testarossa and a miura please (yes I have a 70s complex too).
You going through another Don Johnson/Miami Vice phase Baron?
  • Replies 184
Posted Images
yeah, also watched scarface too many times. and risky business. ok now I want a porsche 928 too.
as for you marlin, don't push it!
i knew you were cool! agree they are fking shit cars and be lucky to outrun a dual amputee in one but they do something to me.
sadly on my list of F40s/countach/diable the 928 is about the only one I can afford!
go tony montana!
I loved the design (the 928 was a car of many "firsts"), but the age of it let it down.
A mate had a very late 5.4 litre GTS I think it was, in red, and I still hanker after one just like it....... I know it would be a disappointment, but they're a future crassic :)
Is that a 924 station wagon? Looks like a z3 hard top lol.
Only 928 I drove was an automatic Hong Kong import one back in the late 90's. I remember doing a 0-100 time at 7 seconds lol, back then the hills area was mostly farmland. Yes it was extremely slow compared to today's standards and even when I drove one. But when they were first released they were actually pretty good cars compared to what else was on the market at the time. Although today a Mazda 3 is just as fast.
Yes, me too. But I'm fussy. Must be either a late 840CI or preferably the very last V12, the 850CSI :thumbsup:
We're sickos Baron.
Definately sicko. Did someone say M635csi?
Check this out. Dont start drooling over the 2002 either.
http://www.bcspears.com/bmw_m635csi_gallery.htm
The 3.0L CSL is where it's REALLY at! :)
Years ago my father had a loan car from John Briggs cars whilst his was in their for some warranty work. The loaner was an M635Csi. What a fantastic car! Much, much better than I actually thought it would be. Not often something surpasses your expectations. :worship:
We're sickos Baron.
for sure, 850 is the go. they are pretty cheap these days but the running costs! my god man the running costs! would make a GTR seem cheap to run.
and yes I'd like a 2002 but most of all a really neat, original E30 M3 EVO (later model with the bettter engine etc).
also totally agree we are sick, sick people. still if you're going to be stuck in a timewarp might as well make it an 80s/90s timewarp. there's barely a car I want to own that wasn't made in the 80s or 90s.
maclaren F1
F40
diablo
E30
etc etc.
even jap stuff was at it's best then and that goes for bikes too.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
