  • Replies 184
Posted Images
Actually buying some of those exotics posted isn't all that pricey.........the crippler is having to buy a flatbed truck and then pay someone to drive it and follow you around every time you go out for a drive!!!
:stupid: It's one thing to buy an exotic, another to live with it ;)
Edited by Iron Chef
Your standards are slipping gents.
werd. I started off with cool shit like diablo's and stuff and now we have some pullme thing and a 356 which i'm fairly certain is not in my golden era and also looks like a sleeker volkswagen beetle (not a compliment!).
ok, let's get things back on track.
just to be difficult I want my diablo to be the SE30 with the sports pack (extra 75hp) which only a handful ever existed. it was the lightweight stripped out version but with 600hp... one day.
also, whilst on the topic of awesome 80s/90s cars can someone please stop fcking mr bean from buying maclaren F1s. he's now written off at least 2 that I know and if he buys another one i'm going to have to go take it off him. how the fk you can write off a maclaren F1 driving straight down a motorway is beyond me. perhaps if he had one girl on each side of him and was getting blown by one whilst simultaneously trying to do lines of coke of the others breasts I could perhaps see how things could get tangled and he might lose concentration for a moment but other than that there is just no excuse. in fact mid crash he should have dived out the window and thrown himself between the car and the pole to soften it's blow. selfish prick.
though if we are going to go a bit older I will make an exception. and my god it's one of my favourite cars of all time. lamborghini miura.... mumma mia!
md_Lamborghini_Miura_SV_-_%28red%29_-_front_left_2_%28Docklands,_Vic,_19_April_09%29.JPG
md_Lamborghini_Miura_SV_-_%28red%29_-_rear_left_2_%28Docklands%2C_Vic%2C_19_April_09%29.JPG
also to the quirky 80s/90s section lets add the Alfa Romeo Sprint Zagato (SZ, but not the RZ because convertibles are for women).
a bit quirky looking but something about them is just "so 90s" and tough. I'd have one. with open pipes to hear that lovely alfa 6 note.
they looked cool in race form too.
and here's a better pic of the standard car (if you can call a zagato bodied alfa 'standard').
btw another fav 80s car while we are talking alfa has to be the alfa GTV6.
and a GTV6 race car.
they made some beautiful cars even earlier too.
for those that don't know the alfa GTV6 is a pretty cool car. it was released in 81 and powered by a 2.5L V6 (beautiful engine) that put out about 160hp. sounds like nothing but at the time a porsche 924 were just over 100hp...
they were front engined but with a rear mounted transaxle (using what's called a de dion rear member) which gave a 50/50 weight distribution. they had other cool feautures like 4 wheel disc brakes with inboard rear disks (very cool), and were pretty rapid for their day.
they also made a 3L (potenziata) version and some rare twin turbo versions too that put out something like 240hp.
the 2.5 is a sweet donk though and can be fettled to make decent power.
check out that rear end and sexy inboard disks etc... pretty cool for a car made in 1980..
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
