basically the car has been crashed. needs panelwork, on front right quarter, both rear quarters, boot, bonnet, needs new front and rear bars, roof and front left are perfect. needs 1 new headlight and 1 new rear light cluster. could fix or just use for parts. running gear is perfect. needs tyres + maybe new radiator or just a hose. havnt got under it to look yet.
the car is completely standard even exhaust. gtr rear wheels colour matched gtst fronts. turbo timer, k&n air filter.
RB20DET
only done 72,000 k's 1st owner in australia. has done 20,000 k's in the country.
$6000
https://www.sau.com.au/forums/topic/37322-93-r32-gts-t/
Would be very interested in some pics as well! Have you been told an estimate cost t repair it, even if it is rough? My e-mails [email protected] Thanks Chris
ive sent you the pics. havnt been told repair costs yet. still waiting on quotes. will post quotes when i have them
https://www.sau.com.au/forums/topic/37322-93-r32-gts-t/#findComment-750234
Nice pics!...
looks like uve hit a pole (?) on the rear drivers side from a drift? then spun out and eased into another pole/fence?
lost it round a corner drivin home from work. the back end hit a tree and i ended up in a garden. beware of pedestrian crossings the white lines are very slippery
https://www.sau.com.au/forums/topic/37322-93-r32-gts-t/#findComment-761802
Has the car been written off on insurance? May be intersted in the rolling shell ( no running gear) if it has the compliance plates on it. Could you pm me a price.
the rolling shell has been sold with most of the interior. all thats left is wheels, steeringwheel, enginge, gearbox, turbo and all the bits that go with those three. the passenger seat and the rear seats.
https://www.sau.com.au/forums/topic/37322-93-r32-gts-t/#findComment-785127
Guest
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
