  • Replies 58
Yeah, I wouldn't bother with the standard r33 turbos because they like to fly apart beyond 12psi.
It's kind of a waste bolting them on to just run 12psi. A single Garrett item with an internal gate would be far cheaper, easier, and a lot less mess under the bonnet.
I'd you're set on twins, get decent twins properly matched for performance vs early spool time.
But, a z32 and two standard turbos at 12psi wouldn't max a z32.
Just advice mate - you need to rethink you're strategy because what you're doing isn't going to be worthwhile, especially on a rb2530
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953446
+1
The sheer cost and effort to get twin stock turbos onto a RB25 head is just not worth it for a start.
Let alone the failure risk and thus motor...
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953510
im a fan of twins but this is ridiculous.
do it properly or not at all.
you can get proper twins or a proper single with the right money.
or you can go cheap and get twin chinas or a single china.
but this is too cheap lol..
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953519
Well, they're supposed to be good for ~200rwkW each, which is a bit more than the Z32 meter will measure. It's just a question of whether you can drive one to produce 200rwkW with only 1.5 litres behind it.
If it were me doing bodgy cheap twins like this, I'd use some TDO4s off a WRX or something similar. They're a bit smaller than the RB25 turbos, will spool better, will run to higher boost if needed to make the flow&power.
Stilll a complete nightmare to do compared to the expected results though.
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953629
I am aware of the risk involved with ceramic turbos but as they wouldn't be seeing a high boost level with 2 of them this wont be an issue. My current turbo has been seeing 14-16 psi at least twice a day if not 20 times a day for 6 months and it's fine. That argument aside, there are some good reasons that I am doing this turbo setup. The cost of doing this is bugger all. Another stock turbo with lines is $150. A head flange and 2 t3 flanges cost me $100 from ebay. I'm getting all the pipe for the manifold and exhaust from work for free. I currently have one hks split dump that I've been using for a while now. I need another split dump or I could use the stock ones. The exhaust and manifold fabrication will cost nothing more than my good company and some drinks at a mates house. The water and oil line setup is another negligible cost. Intake piping is what it is. Silicone bends aren't that cheap but we all know what they are worth. Tuning is up to me. I'm going to tune the turbo setup on the current rb25det in the car and then swap it afterwards to the bigger motor. So it all comes in at less than $500. It will be fine aye. It will be neat and wont blow up :whistling: Also as far as effort goes its not a lot in my book. As the cost is so low that means less wages spent. To get a "proper" setup I would be looking at a minimum of $3500. That's more work in the end. It might sound crazy and risky to some but to me the work involved is easy and the cost is small. It might be a bit laggy? I guess we'll see. It will end up on the dyno after I have done most of the tuning so we'll see then. That's a couple of months off tho, busy with work and home and engine building as most of us are. At the end of the day if it all turns to shit all I would have lost is a small amount of money and a weekend or 2. Have faith peoples. I'm not some chinese whispering 20 year old. :yes:
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953706
It will be laggy and the turbos will only run 12psi.
Why not go a gt3076 or bigger? simple and proven and possibly cheaper.
A bigger single would be the easy way out as far as install goes. I guess I'm doing it cos its cheap and fairly easy and a bit unique. Plus it would give me something to do that I'm interested in. I'm curious to see how it would go. If it turns out crap then a 6boost manifold and a gt3582r will end up on the 2530.
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953727
Max will be 500hp, it's the max theoretical resolution of 1x Z32 AFM
Best post in whole thread! :thumbsup:
IIRC it was a pretty simple and direct question.
500hp seems to be about right. What sort of power are you chasing?
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953809
Whatever the engine/ turbo kit will do. I just pulled the head of the 30 and the bores are 86.05mm. I'm about to sus out the piston/bore tolerance and if its ok then its going to stay the way it is (stock). If it needs machining then forged pistons are going in. Even if it stays stock (or forged pistons) its getting a 3.4 stroker kit next year on the tenth of August (my birthday!). So the power level will vary depending on what work gets done to the engine for now. Either way it only has to last a year so I'll turn it up as much as reliably possible.
EDIT: I'm only running an intank walbro 341 for now so that may need replacing with something better as well.
Edited by Room42
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5953906
chances of getting it done for 500 are slim.. i predict at least 1k and ALOT of stuffing around..
Now considering you can get a 3076 for around 1 to 1.5k second hand that will bolt straight up to a 2.5 with minimal fuss, it will be much easier to work on and diagnose should any problems arise and it would probably kill your crazy setup ..sure it is something different and original but so is the gay mardigra and we dont go there
cool thread though..
https://www.sau.com.au/forums/topic/373237-how-much-boost/#findComment-5954810
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
