I got my r34 today and it has a cat back exhaust and it's really loud I don't really like it that loud rumble rumble rumble
anywho was wondering what I can do to make it softer and nicer toned
would a differnwt sort of muffler sort my problem or would I need a mid muffler?
Any help would be nice :)
https://www.sau.com.au/forums/topic/373241-r34-at-back/
does it have a cannon or an oval muffler? if it has a cannon then get an oval muffler put on there. what size is the piping?
simplest solution though is to take it to an exhaust shop and tell them that it's too loud and they can give you some options to make it quieter once they've looked at the system that is on there.
https://www.sau.com.au/forums/topic/373241-r34-at-back/#findComment-5953709
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
