Im no longer campaining a skyline with an RB engine anymore so im selling off some of the gear that I have no use for
There is nothing wrong with any of these parts, they either dont work with my new engine package or are not up to the job I need them to do.
Fuel System gear Aeromotive 1000hp pump. Brand new unused in new box$400
Aeromotive inline fuel filter 10 micron Brand new unused in new box$150
3 Litre surge tank to suit above pump and filter Brand new unused$200
2000cc bosch injectors Brand new unused direct fit for RB26 matched set $800
Or the entire fuel system for $1400
Cams and springs Apexi Vmax 272 degree 11.2mm lift camshafts, These have done approx 6-7 race meetings and are in perfect condition. No marking or damage. Still installed in cylinder head sitting on the shelf.
Apexi V max springs to suit above cams
Apexi V max titanium spring retainers and collets
$1000 for the whole valve train
Clutch Excedy twin plate PULL type clutch. Done some work but has never been in anything other than my road GTR. Probably 70% life remaining, removed and ready to go
$500
R32 GTR intercooler perfect condition no dents or damage
$200
R34 front end conversion and wide body Never fitted or used. Full kit minus headlights. To suit R32.
$800
Wilwood pro lite calipers 6 piston, brand new never used or fitted. ill check piston sizes
$1000
Wilwood bias controller and master wilwood bias valve, 1 inch master cylinder with no proportioning valve. Braided teflon lines to suit. Suit brake upgrade with bias issues. Used but good condition
$300
Everything located in sydney.
Photos will come when I have time to upload them
https://www.sau.com.au/forums/topic/373302-rb26-parts/
Thanks Charlie I thought they were 272's but there you go.
Cams are as Charlie mentioned 270x11.4mm
The wilwoods will take up to a 370x36mm rotor. I had them mocked up for a 360x36mm rotor which was going to be used on my GTiR project. Gone with smaller 16x10 wheels so they can't be used anymore though.
I'll put photos of the fuel system up latter today
https://www.sau.com.au/forums/topic/373302-rb26-parts/#findComment-5954685
Injectors and one surge tank are sold.
I still have the fuel pump and a surge tank that was specifically designed to suit the pump and filter.
Has a block with 1/8th NPT threads cut for fittings and a male -12 AN fitting welded on at the right height for the pump to line up with.
https://www.sau.com.au/forums/topic/373302-rb26-parts/#findComment-5956059
  • 1 month later...
  • 10 months later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
