in my r30.. every time i jump on the go fast peddel.. my rear tyers go up in side the rear gards and tag the wheel arches...not the lips rite up in side
and 100 time worse with any 1 in the back
i think it had monro gas rear with king spings...( or maybe ebay knock offs)
my question is what can fit.. what have other people done..
or where can i start looking...
thanks
https://www.sau.com.au/forums/topic/373308-r30-rear-end/
Have a look for some KYBs. Any good suspension shop should be able to get them for you.
was going to do a run around today... but was wondering if some shocks and or spings outa some thing else will fit..
the stuff in mine dose not look that old.... but guess crap is crap..
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5954832
You don't want to scrimp on suspension, brakes or steering if you value your life or that of others! Your springs may be ok - just need the shocks. A good suspension shop should be able to tell if your spring rates are appropriate for your car.
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5955682
think its both... cause its the rear... not rubbing any thing but tyers on inner gards... so as much a i dont like it,,,wont kill the car or me.. you put 2 people in the back.. its just not worth the effort... wish i had a pic of the other day
the biggest question i was trying to find out was what else fits......... or just have to find some good shocks and springs and hope for the best?
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5956060
im sure there's new springs available, cause there are springs available for mine.
just had a real good look at the springs.. there king and there the rite ones for the car... and shocks are new too...and they junk.. at the moment i am looking into what else will fit...ie(180sx or some thing)
just if the king springs are ment to be harder.. and better.. guess custom is going to be way...
and the sad thing also is the motor in the car is a stock l24.. just with exhaust and pod.. would under stand if i had 300rwkw..but less than 100..
guess some thing not rite.
will post the findings
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5958917
pic of my 30 with a bit of load... around 2 average people....
still on the look for what else is going to fit..
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5963212
C210 & R30 rear end is same same
S13 rear coilovers fit, but need the top hat changed to a 3 bolt format from the 2 bolt format they come with.
I recommend height adjustable, so you can level out the back of the car in relation to the front.
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5979917
  • 3 weeks later...
thanx to all who helped...got some koni's for the street car.. putting the coilovers in the drift car.. .. will keep up dates and pics as soon as i get a chance to do the cage.. and put her together.. again.. chat soon
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-6006408
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
