in my r30.. every time i jump on the go fast peddel.. my rear tyers go up in side the rear gards and tag the wheel arches...not the lips rite up in side
and 100 time worse with any 1 in the back
i think it had monro gas rear with king spings...( or maybe ebay knock offs)
my question is what can fit.. what have other people done..
or where can i start looking...
thanks
https://www.sau.com.au/forums/topic/373308-r30-rear-end/
Have a look for some KYBs. Any good suspension shop should be able to get them for you.
was going to do a run around today... but was wondering if some shocks and or spings outa some thing else will fit..
the stuff in mine dose not look that old.... but guess crap is crap..
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5954832
You don't want to scrimp on suspension, brakes or steering if you value your life or that of others! Your springs may be ok - just need the shocks. A good suspension shop should be able to tell if your spring rates are appropriate for your car.
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5955682
think its both... cause its the rear... not rubbing any thing but tyers on inner gards... so as much a i dont like it,,,wont kill the car or me.. you put 2 people in the back.. its just not worth the effort... wish i had a pic of the other day
the biggest question i was trying to find out was what else fits......... or just have to find some good shocks and springs and hope for the best?
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5956060
im sure there's new springs available, cause there are springs available for mine.
just had a real good look at the springs.. there king and there the rite ones for the car... and shocks are new too...and they junk.. at the moment i am looking into what else will fit...ie(180sx or some thing)
just if the king springs are ment to be harder.. and better.. guess custom is going to be way...
and the sad thing also is the motor in the car is a stock l24.. just with exhaust and pod.. would under stand if i had 300rwkw..but less than 100..
guess some thing not rite.
will post the findings
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5958917
pic of my 30 with a bit of load... around 2 average people....
still on the look for what else is going to fit..
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5963212
C210 & R30 rear end is same same
S13 rear coilovers fit, but need the top hat changed to a 3 bolt format from the 2 bolt format they come with.
I recommend height adjustable, so you can level out the back of the car in relation to the front.
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-5979917
  • 3 weeks later...
thanx to all who helped...got some koni's for the street car.. putting the coilovers in the drift car.. .. will keep up dates and pics as soon as i get a chance to do the cage.. and put her together.. again.. chat soon
https://www.sau.com.au/forums/topic/373308-r30-rear-end/#findComment-6006408
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
