Post a reply, don't do a quick reply. Look for the "Additional Options" box and click on the "manage attachments" button. Should be able to browse for the pic on your computer and then click ok. The pic will be attached to the post.
hope that helps, cheers.
Hey Munna,
I bought my R32 with the same setup, standard recirculating BOV and an atmo BOV (non-adjustable HKS Super BOV on mine) in the same place as yours. The reason people set it up this way is because they want to run an atmo BOV for some reason (high boost application or they just like the sound), but also want the car to retain idle quality and not to run mega rich between gear changes because the standard BOV will still work to a certain degree. (The cars ECU expects a certain amount of air to be recirculated by the std BOV at these points).
Didn't really hamper performance of the car, but it did hamper performance of the HKS BOV as it hardly even went off most of the time!
So it really seemed like a pointless setup, I ended up removing it for that reason.
Yeah I had the same thing - on 16psi the HKS would work alot harder.
As far as limits of the std BOV - from what I've heard it's pretty variable....I thought mine was leaking at 12psi but have since discovered it isn't. I've heard they hold up to 17psi standard, but can't confirm it, some say more, some say less...
There's a thread on SAU that describes a modification you can do to the BOV to make it hold a bit more boost at the cost of causing it open up a little slower:
http://www.skylinesaustralia.com/forums/sh...read.php?t=9634
.....Additionally, the Americans seem to love our std Skyline BOV as well - it's a Mitsubishi design and comes on a few models they have over there, a few things they've done to make them hold more boost:
Crush it in a vice!
http://www.geocities.com/MotorCity/Garage/...4/crushBOV.html
Physically drill out the small air leak inside the bov and vent it to the atmosphere for slow openning and holds boost up to 30psi, not bad!!
http://www.thedodgegarage.com/turbo_bov_mod.html
Hey CerealKiller,
Yeah, tightening it up so far that it can't open will definitely nullify it!! Of course if you have a pod filter the std bov is quite loud too.....
A friend and I tried this on his DR30 Skyline which has a adjustable Sheepdog BOV, we were able to prevent it from openning at all, such was the extent of the adjustment. Not necessarily good for the turbo (it has no std bov)....but so much quieter, b4 it sounded like a steam train venting every time it went off!
Personally on my car I just went to a jap wrecker and got a piece of intake piping without the mount/hole for an atmo BOV and then sold the BOV!
RaseR
RaseR Blocked the little hole off on the standard blow off valve as in the the posts you listed and I could hardly beleive how much faster the turbo spolled up. Heaps more responive now and atmo blow off valve is louder.
Hey Munna, great result!
I had limited success with the BOV mod (I tried it after removing my atmo bov), seemed to hold boost a little better and opened up later - but I ended up reverting back because on my car it also caused infrequent part throttle surging. So many people have had totally different results from doing this mod.....it's interesting, I wouldn't mind trying the 'Dodge Garage' BOV mod as described in the third article I posted earlier, but haven't had the inclination as yet!!
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
