Doing some random seraching on the net and I came across the following intake/intercooler kit, LINK.
I understand the filters and would be just throw away and use some decent items. Im wondering what the actual piping work on these are like and has anyone used one. The kit is only $300 vs $1200 for the greddy kit. Just food for thought at this stage.
Im after some decent feedback and not the token responses.
https://www.sau.com.au/forums/topic/373442-rb26-metal-intakeintercooler-kits/
I bought a hard pipe intake kit, that goes from standard air flow meters to turbos from Matt at newera parts japan.
Good thing with this kit is you can use the stock air box or aftermarket pod filters as it keeps the afms in the stock location
I can post a pic of it installed tonight when I get home :)
there have been threads on these before. the auto88 kit you posted is a direct copy of the greddy kit. if the fact they are ripping off other peoples IP is not enough to stop you buying it then go look at the threads where people who bought other copy greddy products (including simple stuff like these kits) posted and see how poorly they are made and how poorly they fit. yes the genuine one costs $1200 but nice parts cost money because they are well designed with many hours of work to make them right and they are then well made with good QC and then combined with good quality fasteners and joiners. it's your car but cheap copy piping on cars just spells poorly looked after car to me. it's your money but what's the point saving $800 on the parts if you then go and spend $400 in labour getting it cleaned up and modified to fit and in the end it's still a rip-off of someone else's hard earned design.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
