Hi Guys,
Trying to get some $ together to get my car ready for SAU Nats, so this gear has gotta go - prices are open to a little negotiation
Dunlop Direzza 03G R1 Semi comps in 265/35/18. Heaps of tread, evenly worn and nicely scrubbed in. Probably 85% tread left easily
$1200
BCNR33 GT-R Brembo Brake setup front and rear
Pro respray by Mick at Micolour in BNR34 GT-R Brembo Gold. Perfect if you want the 34 gold brakes on your 32/33 but don't want the extra expense of 34 brakes and then having to drill out the hubs to take the larger 34 mounting bolts
Had a refresh after painting too, so they're pretty much good as new.
Fronts come complete with –
Respray in gold, with Brembo lettering in red – some scratches but only on top of the caliper, not visible once fitted
Ferodo DS2500 @ 35% left
Ferodo DS3000 @ 80% or more
DBA4000 disks with 90%+ life left (less than 3000kms inc a couple of track days)
Braided ADR Approved lines
Stock S14 lines
Rears come complete with –
Ferodo DS2500 @ 50% left
Stock disks – 80%
ADR Approved braided lines
Stock S14 lines
$2600 the lot, will separate provided the rears sell first.
Set of 4 Work Rezax Roar rims. RIMS ARE NOW SOLD
These are the original Time Attack rim with deep taper style spokes. Very good quality rim. 17 x 9" +20 and 5 x 114.3 pcd. These DO clear factory Brembos on the 32/33/34 no problems.
Overall condition is excellent, however a couple of rims have had some gutter loving as pictured. Complete with centre caps.
$SOLD
Power FC for a series 1 S14 - $850
Perfect working order
Sydking - the brakes are a package mate, price is negotiable - feel free to make an offer within reason!
Work wheels now sold :)
    • its funny you linked that video. a friend set it to me last night. i commented there, and checked SAU to see if anyone had commented on my thread and saw someone had posted. will try to help others when i can.
    • My rotisserie is due to be delivered next week and I need to get my R32 mounted on to it. I know how to mount it on the actual rotisserie but those of you that have, did you add any additional bracing to the chassis? I was planning on welding some 1x1 box section across the top of the seatbelt buckles, across the back seats and then down to the front footwells (and possible across from there also? I've also put the behind dash bar back in to give a bit more strength. Its mostly going to be the floor and sills being cut out with a little on the rear quarters
    • apparently people are still having trouble with this as well
    • Only problem with that is it's obvious to the police, but same same with the aes valve. Most people get the valve precat so it's harder to see when looking under the car from the rear.
    • It's been a looooooong while since I did this, but... No, from memory there's a feed ring around the inside of the squirter. Otherwise,  they would have to be too precise when machining the threads in the block, and the banjo bolts themselves.
