Hi Guys,
Trying to get some $ together to get my car ready for SAU Nats, so this gear has gotta go - prices are open to a little negotiation
Dunlop Direzza 03G R1 Semi comps in 265/35/18. Heaps of tread, evenly worn and nicely scrubbed in. Probably 85% tread left easily
$1200
BCNR33 GT-R Brembo Brake setup front and rear
Pro respray by Mick at Micolour in BNR34 GT-R Brembo Gold. Perfect if you want the 34 gold brakes on your 32/33 but don't want the extra expense of 34 brakes and then having to drill out the hubs to take the larger 34 mounting bolts
Had a refresh after painting too, so they're pretty much good as new.
Fronts come complete with –
Respray in gold, with Brembo lettering in red – some scratches but only on top of the caliper, not visible once fitted
Ferodo DS2500 @ 35% left
Ferodo DS3000 @ 80% or more
DBA4000 disks with 90%+ life left (less than 3000kms inc a couple of track days)
Braided ADR Approved lines
Stock S14 lines
Rears come complete with –
Ferodo DS2500 @ 50% left
Stock disks – 80%
ADR Approved braided lines
Stock S14 lines
$2600 the lot, will separate provided the rears sell first.
Set of 4 Work Rezax Roar rims. RIMS ARE NOW SOLD
These are the original Time Attack rim with deep taper style spokes. Very good quality rim. 17 x 9" +20 and 5 x 114.3 pcd. These DO clear factory Brembos on the 32/33/34 no problems.
Overall condition is excellent, however a couple of rims have had some gutter loving as pictured. Complete with centre caps.
$SOLD
Power FC for a series 1 S14 - $850
Perfect working order
Sydking - the brakes are a package mate, price is negotiable - feel free to make an offer within reason!
Work wheels now sold :)
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
    • Is it possible to get them dilled and taped if its not there. Same for oil feed and turbo drain, is it easy to get them taped or i should get the supply from somewhere else?
    • I'm not doubting it does something, there's clearly a reason why Nissan bothered with it on the transmission/diff/transfer case but it's more just the effort of finding a drain plug that isn't going to have some unexpected design problem that makes me lazy. For example even the Nismo branded ones here spec way less than the factory 20 N-m. They say only torque to 10 N-m. That is getting absolutely trashed the moment you take it to any mechanic who isn't familiar with the specific requirements and assumes it should be torqued to factory spec.
    • Same same. DE block has no oil squirters though. You either live without them, or go to the effort of adding them. The type of pain is up to you.
    • Thanks for bringing this workshop to my attention, i didnt know about it before and Jessie did some Fabolous work on my car! Helps that its close to home as well, hate having to drive half way across melbourne for a decent workshop.  https://www.instagram.com/p/DIPwaQ1yHMe/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
