I reckon this is the best thing to do sometimes. Which is hard, because the stock rims aren't that flash and don't allow for very big rubber.
I honestly think if there were easier access to places where people could hoon (drift, drag, burnout etc) that didn't cost a fortune more people would take it off the street. The problem is insurance for the venue, having people sign liability waivers doesn't seem to be enough anymore. People are too quick to point the finger at somebody else for their own stupidity.
It is a pain getting traction with the stock wheels. I'm thinking semislicks will be the way to go. There is a place in Perth ( http://www.motorplex.com.au/ ) where you can go every wednesday and take your car down the strip. Like Uncle Ben said to Spiderman "With great power comes great responsibility".
  • Replies 217
They are a Bosch sensor but it's 1000F not C, so the are quoting 100F less just to cover their ass as they are covering the warranty. Also the closer to the turbo the more often that the sensor will need to be calibrated. The sensors are the same as the AEM sensor but AFAIK the AEM sensor is then calibrated by AEM before they sell them. There is a resistor number on the sensor and when you order the AEM sensor you have to quote that resistor number to get the right calibration.
http://www.bosch.com.au/content/language1/downloads/02_Tech_Guide_Email_Quality.pdf
Check out question 4 in this pdf. Its celsius. I dont know about how often you have to calibrate but mine has been done once and its been a few months now.
the difference in max temps would be at different positions, some quote max EGTs at the sensor, others quote max temp of the external sensor body etc.
the sensor uses a 18x1.5 thread, you can get bungs in mild or stainless pretty cheap off the net if you need them
I've got my wideband talking to my datalogit which is actually a bit useless seeing as the datalogit can only give min, max, or average values. With my girlfriends help I managed to tune my car extremely well using the datalogit for knock and the wideband for fuel. You dont need a dyno to tune your car. My tune was 98 percent of what the dyno guys could do and I would have got it to 100 percent. I just had other things to do besides tuning every time I went for a drive. To answer your question straight up, any lag time that is there is almost nothing and wont affect your ability to tune it properly.
datalogit can do more than min, max and average. if you know what your doing you can get the exact afr at any given time, load, rpm etc in several different ways. the graph function is actually very handy for knock as you can see exactly where on the map the ecu was reading when it knocked, i dont mean which cell, i mean exactly how far between 4 cells and what the timing was at the time. the cell the knock value pops up in isnt always the culprit due to interpolation, same goes for fuel.
I'm pretty sure I got a bung or 2 with the wideband kit.
I haven't used the graph function yet. I'll have a sus tomorrow. But... The reason I said it was pretty useless is because the fuel in a cell will be different a lot of the time. Like light load acceleration will using the same cells in high rev deceleration and it will even be affected by acceleration enrichment when you plant it. You end up with 3 different afrs in the same cell as far as the datalogit is concerned. I've seen a max of 21.9:1 and a min of 10.X:1 in the same cell.
you can eliminate those by adjusting the max and min values it displays, it still eliminates them from the average. or again you could do it with the graph function, or even looks through the raw log files. theres several ways to do it without being affected by fuel cut and other factors.
also, i've found that apart from the first split second fuel cut almost always ends up in P1 or P2, as your almost never cruising in those cells i just left them standard
Well it seems that you know more about the datalogit than I do. Being a bit lazy and since we're both in Perth maybe we can catch up and you can show me some stuff with it. No homo, the missus would disapprove :rofl2:
he might reconsider if you buy him some booze :P
Good one snozzle :laugh: I've got about 5 cartons of home brew here. Although the last time I tuned my car when I was drunk it ended up being ridiculously rich. I was changing water temp correction on a cold night. :no: P.s My holden loving mate was driving and it converted him :yes: He couldn't get his head around 2.5 litres making the same power as his very worked 5 litres. :D
Do you guys use the supplied heatsink that the Innovate comes with? (well both of mine have had one) Or just weld in a bung like the OEM one?
If you use this, then the sensor itself isnt in direct flow of the exhausts gasses. The tip of it barely enters the flow. Just enough to give it a sniff as it flows past. lol.
Im pretty sure they give you this for that exact reason.
Im like someone else that mentioned it earlier, welded it into the de-cat pipe as its conveniently located near the cat wire grommet. And a good distance downstream. I figured seeing as i do track my car a bit it was the better place for it. Im not overly fussed with re-calibrating it, do it each time i change the oil and plugs. Takes 2 mins.
I just screwed mine into the dump with the copper washer that came with it.
I'll add something about distance for the sensor.
Was talking to a mate of mine last night who used one of these in his WRX (around 220awkw) for 4 years with the sensor right behind the turbo and he never had any issues. I'm not about to move mine from the de-cat as it's convenient for me but that info might come as some comfort for others who want to run it in the dump :)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
