ROH 18" x 10" 3 peice Modena's $3500
Michelin 270 full slicks fitted
3" of dish
Three layer pearl
Used for one day only
Decided to include all my slicks. Thats 15 in total!!! 270 Michelin's. They are all used and in various levels of wear. All are usuable!
Insane deal, get in quick.
Matt
0413023669
https://www.sau.com.au/forums/topic/373502-roh-modena-18x10-with-15-slicks/
  • 1 month later...
  • 1 month later...
Reduced to $2000 from $3500 to get them out of the shed.
Thats right, full package for $2000
One off custom size and colour.
offset was designed for max offset without going over 10" for optimal rotational mass
Inside of rim painted black from the factory as per race spec(hides rotor dust)
Matt
Adelaide
Can courier for $
Edited by BoostdR
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
