August 27Th Drift Practice - Entry Forms Inside
Okay boys and girls, this is it. The LAST drift practice day for 2011!!
This will be your last time to get out on the track in a non competition day. For anyone new to the sport wanting to have a go now is the time! Driver training and practice runs from 10am until 4pm Saturday!
As on the flyer $130 entry fee (CAMS and club membership - available on the day).
Baskerville Raceway is one of THE BEST drift tracks in Australia so take the opportunity to start learning on an ideal track!
AND an exciting new addition to the practice day time table, our Clerk of the Course has allocated 1 hour between 11.30am and 12.30pm during the next practice day/come and try day for sponsor rides. All sponsors must be proven to the Clerk of the Course to be legitimate sponsors and they must sign a Passenger Disclaimer before getting into the vehicle.
Drivers will also have the opportunity to ride together for training and development purposes throughout the day. All runs with passengers will be single runs. If you intend to put a passenger in your car you must declare this to the scrutineers at scrutiny and your car will be marked accordingly so that start line can identify those eligible.
It is important to note that a CAMS compliant roll over protection structure is a cage that satisfies the current FIA standards as found in Schedule J of the General Requirements in the CAMS Manual of Motorsport, which can be found here: www.cams.com.au or in the attached document.
You do not need to have your roll over protection structure certified and log booked to be able to take passengers on a drift practice day, it just needs to be CAMS compliant as per schedule J attached, and the scrutineers need to be satisfied that it is indeed compliant with the schedule. However, Drifting Tasmania recommends that you do have your rollover protection structure certified by registering your vehicle by way of a log book.
All information pertaining to the event is contained in the attached supplementary regulations, and I have attached some CAMS information regarding roll cages in vehicles ;)
Approved Supplementary Regulations.pdf
GQ11_Schedule_J_Q311.pdf
I'll be at the drift day with bells on!
You'll be easy to spot then :w00t:
:ph34r:
not sure i'll get the ceff ready as there's a fair smack of work to finish it off , and i have to find front rimzzzz now , but i'll be there to spectate if it doesn't go to plan
:ph34r:
I've got a pair of 17"x7 +38 if you want to borrow?
hey all im pretty new to the scene so bare with me haha..
im a member of hscc but i havent got a cams license, is cams required to enter drift practice or is cams just required to compete?
how much is a cams license because if its required i might be a tightass and wait till next year and get my years worth.
cheers :cheers:
Hey Jack,
You can get a CAMS licence on the day, I can't remember how much it is exactly but I think it's like $110.
Your licence lasts for a year from the day you pay for it so you don't need to worry about buying it at the right time to get your years worth.
Looks like I have to pull the pin on this one. My WRX is a spit of jealous rage stole all the money I had put aside for this event :(
Edited by zoidbergmerc
When he got it, the tune was for the 2871r which it had before making 240kw, but was swapped for a gt-ss, but tune wasnt adjusted so was running mega rich and washed down the bores on the first motor, so he swapped the blocks with a healthy motor, had the tune touched up by a workshop (won't mention who) so was ment to be fine, then less than 1000kms later same thing happened... so motor came apart and got new rings etc, then went to pro auto for a new tune from scratch.... had some trouble with cams being dialed in so only made like 170kw... got all that sorted and then re-tuned with a t28 as the gt-ss blew, made 201 kw on a nice safe tune :)
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
