hey guys,
finally got around to finding some injectors to work with.
i can get these 38mm bosch id1000's
http://www.fuelinjectorconnection.com/shop/index.php?_a=viewProd&productId=211
or get these 48mm bosch id1000's
http://www.ebay.com.au/itm/BOSCH-ID1000-1000CC-FUEL-INJECTORS-LS1-9-3-4-LENGTH-/360275679335?pt=AU_Car_Parts_Accessories&hash=item53e21a9867#ht_3187wt_907
now the 38mm units will be better for clearnace.
just want to double check that they will go onto my rb25 with a 14mm top feed rail.
cheers
https://www.sau.com.au/forums/topic/373528-injectors/
i can fit the 3/4 in with a SLIM style rail but thats a 11mm rail so i would need to mill the injector holes to 14mm (machine shop)
but i was thinking if i got the 38mm i could run the 11mm top hat to bring them to 48mm and then run the 11mm rail.
just need to make sure they will go in no worries
https://www.sau.com.au/forums/topic/373528-injectors/#findComment-5958053
and? doesnt really show me how they fit?
anyway i ended up ordering the 38mm injector with a 11mm top hat to bring the length to 48mm (3/4 size)
fingers crossed. if they are still too tall ill take the top hat off and run them as a 38mm injector with a 14mm rail.
so ideally i can come down 10mm in height if i NEED to.
$65 per injector is damn good!
https://www.sau.com.au/forums/topic/373528-injectors/#findComment-5958462
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
