  • Replies 95
Guest mark32
Here is the car i helped crew for, unfortunately it had an off and was out of the race, after it went to hot over a deceptive crest at the ross stage on saturday. Up until then this the car was perfoming faultlessly with only routine maintainence being done on it. If anyone has some footage of it, would love to see it. I saw some footage of the accident on saturday night on channel nine in hobart, but would like a copy so if anyone has it please let me know
hey mark32, that doesn't look to bad after all. Apparently it did make the channel 7 news but we all missed it :) They were running 46th when this little "incident" happened so they were going pretty well for newbies :D
While I wish that skylines would have had a better result but knowing tony, I would rather he get the result...
Always next year!
BTW he only had the current car for a few months... If it is any consolation it was in teh S202 which is a factory homologated car for these types of events, sort of lilke the Nur Spec GTR's
So that isn't your car mark?
Whoevers' car it is will be really pleased with your expose! BOV looks like a non Nissan item to me...
To all those who finished, well done! To those who tripped up, chin up...
Targa is like a drug. I have just had sponsors meeting and received commitment for next year.
But regardless, it is a 4WD event, and when we front next year - it will be in a 4wd.
Don't know category 8 or Cat 9... Some pics on our review link.....
Thanks for all those who showed interest. To the marshalls and volenteers... without you there would be no Targa. And Sydneykid, for his personal assistance - I'll send you the graph Gaz - to put a competitive package on the track.
Love yus all, TT
Photo courtosey of
http://home.iprimus.com.au/cybernoir/targa2004/two/
so I'm guessing that Bovs must be standard then?
My appoligies for not reading the rules, I'll take greater care next time. :P
Do you know what the ruling is on exhaust systems, some gtr's had standard exhausts while others had much larger non standard items
The pipe is to be the same diameter external as the OEM item immediately before the first muffler/cat
I would suggest some pipes in Targa are not legit, but the people get away with it cos they are running outside outright contention...
Ask the R34 owners in this years event... I believe they were copping some heat from a certain Black Monaro.
The exhaust rule is Exhaust: It will be possible to:
either remove the inside of the original silencer,
or modify the exhaust from the first silencer to the exit, the maximum
dimensions of the duct being those of the pipe situated upstream of the
first silencer (see drawing No. 254.3). Should two inlets exist in the first
silencer, the section of the modified duct must be less than or equal to the
total of the two original sections.
Only one pipe may be present at the exit, unless the original part is used.
The exit should be situated in the same position as that of the series
production exhaust system.
These liberties must not entail any bodywork modifications and must
respect the laws of the country in which the event is run with regard to
noise levels.
Additional parts for the mounting of the exhaust are authorised. If an
exhaust silencer is added, it must be of the original type and must contain
noise-absorbing material.
If it is fixed directly to the manifold, the catalyst may be replaced with a
conical part of the same length and with the same inlet and outlet
diameters. After this part, the exhaust will be free with a tube diameter no
greater than that of the outlet from the catalyst.
Note: The above regulations were written to cover under 2.5 litre, front
engine cars for rally use. A number of vehicles that are entered in Targa
Rallies have exhaust systems as standard equipment that cannot be
modified to the above regulation. Note therefore the following clarification:
Competitors with vehicles which have an exhaust system fitted as
standard equipment having two separate pipes, each routed down
opposite sides of the engine, are permitted to modify the exhaust as
follows:
(i) The catalyst may be removed and be replaced by a part having
the same length, and the same inlet and outlet dimensions. At
no point may this part be any larger in diameter than the largest
inlet or exit dimension;
(ii) No pipe in the system may be of a larger diameter than at the
corresponding point of the original pipe;
(iii) The silencers may either be replaced by silencers of a similar
type and containing noise absorbing material, or it is permitted
to remove the inside of the original silencer.
(iv) The exits shall be situated at the original position as that of the
original production exit, and the original parts present at the
exhaust outlet must be re-used.
TT
!!R4 on Cr.
The footage made the Targa Party Tape... and I'm sure it will make the TT04 Tape which goes to air in Tassy Late May, TEN network in June.
Did your team do a recce? See ya next year
TT
Guest mark32
by recce do you mean writing their own pace notes? if so they did not, they were using someone elses and they told me it went like this "r5 on crest", no double cautions, if it had the double cautions they would have gone slower over the crest and i dont think that a 5 corner was the right call either, says a lot about being careful with using other peoples notes
We actually transfer all the TS road book comments to our notes - (we do our own) - and this helps if we miss something. The hardest thing is to keep notes consistent, and even the pro's lack that sometimes...
R5 in a 1-10 format is about right, its the "ON" part that catches most out. Even so we have ours noted with a "care", but I know the course and wasn't flying blind. (didnt help at Sheffield though)
See ya in '05
TT
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
