  • Replies 43
Yeah well he wanted to have a go about my rear windows bein tinted n I told him its factory uv cut glass fitted in japan not tint and it was complied with it in 08 and 12months ago reregistered with it n he all he said back was "well whats legal in japan is different to australia." But I know there looking for things to make life difficult but I asked him if hid's were legal and he goes yeah just have to get permits I was like yup you have no idea :) cause i know for a fact if they arent in projector headlights with self leveling they arent legal so I know there just taking th piss
i know this aint going to help but at the end of the day they will win. . .the coppers can even defect you for worn windscreen wipers and no water in the windscreen washer bottle
Yep. Someone I know got done for a 'dusty indicator globe'.
i was done on the rising sunday for the guards didnt raise my car or anything and just went to the pits and they passed me the cops are just being dicks and picking on us
Doesn't mean the cops are being dicks. Means you got off easy. I've passed the pits with things that are clearly illegal. It depends who you get on the day. Just because the inspector passes you doesn't mean your car is legal.
Martin stfu you're being inflammatory.
Stop it.
The police are not ignorant, they know what the laws are, they're simply doing whatever it takes to see how far and who they can push, they're getting runs on te board for the extra biscuit at the end of the month...
As for recording - it is completely LEGAL providing that You tell them straight up that you're recording everything. The police are allowed to say no IF they wish to leave you alone,
Basically if they refuse to be recorded, they're not legally allowed to have any further discussion with you. Police are allowed to be recorded in this state and personally I recommend you all to do it.
they make our lives difficult and belittle us. Why not do it back to them?
Anyway, this particular subject has been done to death. Greg I'm sorry to hear man, I would probably be taking the issue up with the officers station to make a complaint. But yeah, you now need to take time off your day / off work and pay some shmuck organization to pay for a service you never requested.
Furthermore, Martin you said "it depends who you get on the day"
^^ this is the biggest load of shit ever, like yes you're right. But it just further cements that no dealing with this system are consistent at all,
I mean what. Depends on who you get on the day that decides what is and isn't legal? I thought the law was a book that clearly dictates laws and cannot be f**ked with. Huh.
I mean Joe at the pits can pass your car HE says as legal then officer harvey can pull you over around the corner for having what HE says is unsafe distance between tyre and guards???
It's bullshit. He said this he said that bullshit. "legal" has nothing to do with it
Yeh not true. My mate got in a lot of trouble for recording a conversation with a police officer. What's more, when he took them to court, his recorded evidence was dismissed as it was 'not acquired lawfully'.
law states as long as you are part of the conversation, you ARE ALLOWED to record the convo!
my soarer passed the pits when it got regoed, i had 8.5" rears (jzs147 aristo rears) 7" being the limit on the soarers, and a computer for adjusting the stock air suspension, told them the air suspension was factory, didnt care bout the controller, didnt look at the wheels, bam plates on it driving home!!
wat if its done safely, even if its illegal, 9/10 times theyll let it fly!!
Nope the law stats that you need to have a spare tyre at all time's.... run flats in WA are not a way to get around our ancient laws...
I believe you are mistaken:
"You are not obliged to carry a spare and it does not have to comply with the legal requirements while it is stowed away. However, when fitted to the vehicle (for example, following a puncture) it must then comply with the law."
Rowan, I agree with you man. I'm simply being realistic.
"You are not obliged to carry a spare and it does not have to comply with the legal requirements while it is stowed away. However, when fitted to the vehicle (for example, following a puncture) it must then comply with the law." exactly what ive been led to believe. . .you can carry a spare tyre that is flat/bald/ f*kd or whatever , as long as your not using it
Will they say anything about turbo flutter?
Probably not, but if they know what they are talking about then they would know that flutter makes your car run rich, hence increasing emissions. I doubt it though.
If they ask, just say you ran over a pigeon on the way there and it might still be stuck somewhere.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
