Firstly, thanks to Scott for a few pointers (as usual).
It really is pretty simple - the hardest part for me was putting it back togather! :blush:
1. remove the 4 screws from under the wheel/dash
2. The and bottom plastic cover can be detached. The just pop off.
3. remove the right stalk by pressing in the clip (there's a corresponding one on the bottom of the stalk as wel)
4. remove the left stalk. Same deal as the right stalk except you need to unclip a wire harness. Use a flat blade screwdriver to press down the clip to undo the harness.
5. undo the bolts which hold the instrument cluster to the dash. There are 4 bolts - two front and two back. Funny thing was I was missing a bolt - which is not surprising and confirms
that our cars (and most imports) are f**ked with either here or in Australia. Someone must've changed the dash and forgot a bolt :angry:
6. Take the plastic cover off the ignition barrel. remove the two large harnesses which connects the instrument cluster to the car on the back. The whole dash/cluster should come out now.
7. There are 4 screws (two front, two back) which needs to be undone; then undo the clips (there's a few of them) and the cluster should seperate from the dash.
put in your nismo cluster (or if your a dodgy prick...another car's cluster :whistling:)
Then reverse the steps above to fit it all back.
Hope it helps!
https://www.sau.com.au/forums/topic/373536-m35-instrument-cluster-removal/
Nice write up. Pictures really are worth a thousand words! Even though I have no immediate requirement to remove the instrument cluster, at least I know how. Thanks :thumbsup:
Thanks for that Jethro. I'm guessing my car will have all the bolts as it came here with 100,000 on the clock- unlike the 57,000 that most of them have (they must have a reflashing tool with the same k's on it over there!).
On that, are the k's determined by the dash- so now you have the k's from the nismo dash rather than your car?
Oh, and someone needs to cut their nails, talon-boy :rolleyes:
LOL...
The K's are stored in the dash...yes now I've gained 50k km on my car...
not that I care...not selling it anytime soon (the car that is)
Good idea. I wound the clock back on mine about 14k when I put the new dash in, but I'm thinking if I keep the original it should be ok when I sell it, as I can show them k's on both if necessary.
The car does look its age though, doesn't look thrashed, so I'm sure it's fine. Just need to recover the steering wheel.
  • 1 year later...
so i had some time to try replace my stock cluster with my nismo one... this guide was helping perfectly until i had to remove the ignition and surrounding plastic from the stock cluster underneath.
the bottom and side clips seem to come off easy but for all my trying the top clips will not come loose. I have stopped for now through fear of breaking something...
Did others have any issues with this step at all? I'm at a complete loss at what to do now...
Cheers
  • 7 months later...
    • Thanks heaps. So basically, bare block, very very similar. And cranks are the same
    • Hey guys, I have dipped my toes into the pool of skylines finally and figured I would get amongst the forums and make an introduction post! My name is Callum, I'm from the north side of Sydney, and I am now 6 months into owning my 1992 R32 GTS-T (already having half of that time off the road in true nissan fashion). It is originally an AH3 car but at some stage of its life it has been resprayed in and out in TH1 with (in the sellers words) extra purple, parked next to an actual TH1 car it is a fair bit lighter in colour. It has also had the original RB20 swapped out for an RB25DET NEO which I presume to be out of a Stagea going off the AWD sump that has been sealed up. I won't go super into detail with mods as I want to create a build thread post soon. Unfortunately the car seems to have had a hard life as many of these have being previously a cheap sub 10k car, and I have barely any history on it so if anyone happens to recognise the car or thinks they may have any history I would LOVE to hear it as I am a bit of a nerd when it comes to car history, the seller had it roughly since 2020 I believe and was from Parramatta area if that helps. Look forward to being a part of the community, I have been to 2 SAUNSW events already (one being in 2022 prior to ownership, and once more a few weekends ago) so you could say I am not brand new to it but can definitely be more involved via the forums! (side note: I am pretty new to forums and struggled to attach pictures of the car, is there an easier method than having to have the pictures on facebook and copying the link from there? would love to know for future reference cheers!)
    • I have GT2860R. I'm not sure if they are -5 or -7. Do you know? These are the exact ones.  https://www.enjukuracing.com/products/garrett-rb26dett-gruppe-n-turbo-upgrade.html?srsltid=AfmBOopSCzHaDtf7nggL6R8KrD8RJP4wxBJitmkRmswmv2SaEbAVcxTe And to be honest, i think the car was the most enjoyable to drive on the streets when it was 280hp (205kw). I could enjoy all the revs to redline i wouldn't be going crazy fast, but just fast enough to know that you are working the car.
    • If i used a cooling system pressure tester, would it show me a leak with the head gasket? Ive used one before to chase down a leaking coolant hose. Not sure if this will work on the oil-cooler warmer.
