mythbusters isnt needed dude. some common sense and thought is all that is needed :P
the inner and outer circumference cant be changed. the inside being the rim size, ie 18". no matter how wide that rim is (within reason) its always 18"
the outside, the rolling diameter also remans the same because only the sidewall angle changes. it doesnt get longer, or shorter.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967232
  • Replies 49
ahhhh lol but thats why the rolling diameter DOES change!
i give up. you win by default lol
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967240
i dont want to win im trying to explain how it doesnt change
its also steel belted so it cant change.
only the sidewall angle can change to suit the rim width, yes the sidewall will flex. but thats half the reason why the tyres are filled with air.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967242
something would have to change as you get some pretty big angles when stretching tyres (big angles for engineering are anything over 5°)
but you are correct, the cylinder that makes the tyre cannot get that much smaller (but the rubber is elastic so it can contract a little bit)
so the sidewalls must either get dragged inwards on the rim or stretch a little
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967248
based on the fact that the sidewall will physically stretch, and that rubber is softer that the steel belts, your right. makes sense now. if it was all rubber, physics simply wouldnt allow it.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967250
the sidewal is designed to flex and distort. its normal for a tyre to do that (within reason) but when you stretch them, youre not allowing much movement. thus the tyre is 'firmer' and doesnt allow it to..... squirm?
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967640
i know im goin to get flamed to death for saying it, but IMHO the federal 595 is highly over rated on a daily drive car. they are great for a weekend warrior or if u do ALOT of hard cornering. but for the daily commute i'd suggest something thats a little better in the wet and maybe wears better. i also agree with the other guys a 245 is pretty narrow on a 9.5 inch rim. id be goin a 265 to protect the rim a little better.
I'll be flamed with you then. The wife had a big accident on Bells Line of Road going down into Lithgow on these. Conditions were wet. Now, not saying that it was entirely the tyres fault, thats impossible and stupid to even consider that. However, I believe tyres play a big part of the dynamics of a car. Needless to say, post accident, Pirelli tyres went on all 4 corners.
I wouldn't consider buying them again, but thats just my opinion/experience.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967693
i understand what your saying. but they are right. try it for yourself. head down the tyre shop with an 8inch and a 9inch rim and have 2 identicle tyres fitted and inflate them to the exact same pressure then messure the circumference. there will definately be a difference. it wont be much (0-5mm), but they will be different. you answered it yourself when u said:
"the sidewal is designed to flex and distort. its normal for a tyre to do that (within reason) but when you stretch them, youre not allowing much movement. thus the tyre is 'firmer' and doesnt allow it to..... squirm?"
the stretched tyre is under tesion and cant balloon out where as the unstretched tyre will. thus changing the circumference
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5988174
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
