mythbusters isnt needed dude. some common sense and thought is all that is needed :P
the inner and outer circumference cant be changed. the inside being the rim size, ie 18". no matter how wide that rim is (within reason) its always 18"
the outside, the rolling diameter also remans the same because only the sidewall angle changes. it doesnt get longer, or shorter.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967232
  • Replies 49
ahhhh lol but thats why the rolling diameter DOES change!
i give up. you win by default lol
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967240
i dont want to win im trying to explain how it doesnt change
its also steel belted so it cant change.
only the sidewall angle can change to suit the rim width, yes the sidewall will flex. but thats half the reason why the tyres are filled with air.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967242
something would have to change as you get some pretty big angles when stretching tyres (big angles for engineering are anything over 5°)
but you are correct, the cylinder that makes the tyre cannot get that much smaller (but the rubber is elastic so it can contract a little bit)
so the sidewalls must either get dragged inwards on the rim or stretch a little
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967248
based on the fact that the sidewall will physically stretch, and that rubber is softer that the steel belts, your right. makes sense now. if it was all rubber, physics simply wouldnt allow it.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967250
the sidewal is designed to flex and distort. its normal for a tyre to do that (within reason) but when you stretch them, youre not allowing much movement. thus the tyre is 'firmer' and doesnt allow it to..... squirm?
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967640
i know im goin to get flamed to death for saying it, but IMHO the federal 595 is highly over rated on a daily drive car. they are great for a weekend warrior or if u do ALOT of hard cornering. but for the daily commute i'd suggest something thats a little better in the wet and maybe wears better. i also agree with the other guys a 245 is pretty narrow on a 9.5 inch rim. id be goin a 265 to protect the rim a little better.
I'll be flamed with you then. The wife had a big accident on Bells Line of Road going down into Lithgow on these. Conditions were wet. Now, not saying that it was entirely the tyres fault, thats impossible and stupid to even consider that. However, I believe tyres play a big part of the dynamics of a car. Needless to say, post accident, Pirelli tyres went on all 4 corners.
I wouldn't consider buying them again, but thats just my opinion/experience.
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5967693
i understand what your saying. but they are right. try it for yourself. head down the tyre shop with an 8inch and a 9inch rim and have 2 identicle tyres fitted and inflate them to the exact same pressure then messure the circumference. there will definately be a difference. it wont be much (0-5mm), but they will be different. you answered it yourself when u said:
"the sidewal is designed to flex and distort. its normal for a tyre to do that (within reason) but when you stretch them, youre not allowing much movement. thus the tyre is 'firmer' and doesnt allow it to..... squirm?"
the stretched tyre is under tesion and cant balloon out where as the unstretched tyre will. thus changing the circumference
https://www.sau.com.au/forums/topic/373541-tyres/page/3/#findComment-5988174
    • Hmmm. that's a tough one. There's a lot of history bundled up in that lot. Perhaps instead we can create a new pinned thread, called "Legacy Pinned Threads" and provide links to the these ones that will be unpinned in there. And maybe put the names of the pinned threads that are linked inside in the tags so they can seen from the outside? Or something like? I mean, it's half a step back towards having a more complicated forum structure, without actually having it. But there's a reason that heirarchical architectures exist. They are logical, and if executed properly, make it easy to find something without having any upfront knowledge of where it would be , and without using a search function.
    • Can we unpin a bunch of dead / irrelevant threads from: https://www.sau.com.au/forums/forum/8-engines-forced-induction/ New players at home will scroll and think this forum is dead.
    • It's all about selling non-compliant emmisions stuff, and things like tuning stuff that makes your car have more emmisions, a very small percentage of modifications and tuning go into race cars, the vast majority of tuning and mods, like catless exhausts, or non-compliant cats, go into street cars with registration  Like a gun shop can only sell to someone with a gun licence, if they don't, they are fined and even jailed, and whilst a gun is totally different to a tune, or a catless exhaust, they are still illegal for a street car As for customers, it easy, they send a letter and tell them to show up for an inspection, like if someone says your car is to loud now, if they don't show up for the test, they can cancel rego, just like not paying a traffic fine This has been happening for years overseas in other countries  I'm in no way happy about it, but, I think there is definitely writing on the wall for modern cars with emissions standards, which will effect tuning shops, parts suppliers and end users And like other countries around the world, it is the government's that makes the rules and regulations for street cars with rego What would happen to a tuner or workshop if they were investigated about turning off stuff in a ECU IRT emmisions stuff like engine check lights for cats, or removing cats, or putting in a lower cell cat, this is apparently all illegal IAW modifications to registered cars, or, retuning the car so that with even stock emmision stuff still installed, but due to the tuning, or parts, like bigger cam shafts, it will now not pass the emmisions test Yes, I am going into a rabbit hole, but going off what other countries are doing IRT everything related to emmisions........cars, trucks, manufacturing, mining, modified vehicles are a easy target Meh, time will tell how it goes either way
    • This^^^ 100%. Endless Male Attention. "buy a cool car, attract females". No reality is the opposite. "Buy a cool car, attract males".
    • Just wanted to share the recent dyno results on my car. 20lbs of boost on pump gas. Pulled the fuse on the AWD so it was only rear wheels on the dyno. It made 484 hp at the wheels. I asked the tuner to see if we could do something so it breaks the 500hp level, but he said that we were maxxed out on pump gas. If i wanted to make more power, id have to go to E85.      8739a97a-9408-4eeb-b769-108ff1678736.mp4
