Nissan 200sx s14a Series II Australian Spec 97 model
Looked after really well, This car has heaps of extras.
I purchased it over 5 years ago with 140,000km on the Odometer and iv only traveled 34,000km over 5 yrs. (i have paper work to prove) This was my weekend car.
Really great car to own and drive which is why i kept it for so long.
(scroll down for many pics of the car)
174,000kms
4 Speed Automatic,
Air conditioning,
Power steering,
Electric windows - mirrors,
Drivers side SRS Airbag,
Key less entry,
ABS,
Mods/ extras.
I have listed some of the prices of the extras that had cost me.
*Upgraded to a Garrett T28 Ball Bearing Turbo* Cost $1100 including labor.
* Braided Turbo Lines*
*600x300x76 Front mount intercooler* Cost $750 including labor.
*3inch Bell mouth Dumppipe* $150
* Stainless Steel Turbo back 3 inch Xforce exhaust* *including a Xforce high flow 3'' Cat*
Cost $1600 Fitted (Really nice Note)
*Turbotech manual boost controller set at 8 psi (Never ever boosted this car anymore)*
* New s15 fuel pump*
*Trust style bigger 5 Litre Engine Oil Sump* * Cost $480 fitted
*Apexi Turbo Timer* Cost $140
*Lowered King Springs all around* Cost $450
*Brand new 205/55/16 Quality tyres all 4 which cost me $500 a few weeks ago
*Heavy Duty Bosch Battery Cost $220
*Tinted Windows. Cost $400
*Clarion Mp3 Player with 6 Pioneer speakers including tweeters for premium sound! $500
*Auto-meter Boost gauge* $100
* Brakes painted bright Red*
•Still running the Standard bov / Standard Airbox & Snorkel
Engine runs really smooth, the gears change perfect, Very nice to drive.
Fuel Efficient, 450km to a tank or over 500km highway driving.
I have owned this car for 5 years and have looked after it very well. Never had any problems with it at all.
serviced every 4,000kms with premium synthetic oils, have recently got all fluids changed including Diff & transmission oils all premium oils, All Belts changed recently.
Both front hub assemblies got changed with genuine Nissan parts. which cost me $850.
Spent thousands on this car, never abused it or thrashed it, Never taken it to the drags. Just appreciated it.
This car has never been written off. You're more than welcome to have it checked.
Car has new registration plates as i had personalized plates and removed them for the car.
Will also provide the factory rear spoiler to the buyer.
Registered till October 2011, Buyer will need to organize roadworthy
Car is available to be viewed in TaylorsLakes Melbourne
Please no Tyre kickers or test pilots.
$8500ono
Call me on 0422756270, sms me if i dont answer and ill call you back.
Cheers.
Edited by G4orce
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
