Hey all,
I am having dramas with a Motec M8 in a R33 GTR.
When I purchased the car it was running the Motec M8 and the standard ECU, the car is a ex Targa Tas car, and as I believe in the regulations the car had to be able to be run on the factory ECU and that is the only reason the stock unit was in the car.
Now after about 1 1/2 years I have rebuilt the car and rewired the whole loom with running the Motec as the standalone ECU, but...
The motor seems to be only running on 4 cylinders
All the injectors and ignition all work fine in diagnostics, but once started cylinder #4 and #6 do not work, it seems cylinder #1, #2, #3, and #5 are the only ones that work.
I have now run out of ideas... I have checked/changed:
Spark plugs
Injector wiring
Injectors
Coil pack wiring loom
Coil packs
Ignition module
Ignition module wiring (IGN1, IGN 2, and IGN3)
Ignition coil firing pairing (1/4, 2/5, 3/6)
Crank angle sensor
Crank angle sensor wiring (8v, sync, ref, and ground)
Compression tested all cylinders 150psi
All were fine with no errors found.
I spoke a local well respected Motec tuner today to see if they had any ideas or could look at the car with a scope and they said it is too difficult to get a Motec M8 to work on a I.T.B RB26 and I should be looking at another ECU... I don't understand how that is possible...
I am now thinking of sending the ECU to Motec to have it inspected/tested for any faults and flashed back to factory settings.
Anybody done this before? any ideas?
Thanks.
https://www.sau.com.au/forums/topic/373635-motec-m8-in-r33-gtr/
Targa doesnt restrict ECU choice like that but you've found out why they would have kept the stock ECU in there - run the injectors.
Not sure if its a limitation of the M8 or not however but that's not the first time i've heard of that being done with M8 & stock ECU kept in place for that purpose. Seems odd that it would be needed :glare:
I run a Motec M6 on my GTR- no problems, but on the road throttle response needed tweaking- you need to run throttle position map too account for the ITB's, or something like that. Runs sweet now, I imagine an M8 should do at least the same. If you want the number for the guy who tunes my car let me know- he's usually clued up to ecu's, and has done motecs on GTR's a number of times as far as i'm aware.
Yep, running M800 here and no dramas like you are having. And yes the motec runs the injectors - I don't even understand why you would keep the stock ECU to run the injectors - doesn't that defeat the purpose??
Sorry I can't help you with your ignition issue, but on the point of Motec running ITB's, yes indeed you can. As Doo-Doo pointed out, tune it all up on TP, then do a secondary load map based on MAP.
Have you tried asking the question on the Motec forum in case they can help?
Back in the old days Targa did have a lot more restrictions, one of which was ECU.
There was ways to get around this with piggybacks and stuffing aftermarket ecus in the factory casing.
Who's car did you buy? The only ones I can think of that may have been/are for sale are Jeff K's white one, Leo's Black one and Brendan's white one
Thanks all for the replies!
R31Nismoid- it was a rule a few years ago? they might of removed it over the last few events maybe?
doo-doo- that would be awesome if I could get in contact with some one that has done this before on a GTR, I am in Brisbane also.
R32 TT- Thats what I thought, why run a motec and a stock ecu together, I wanted the Motec to do it all, I have searched the Motec forums and posted a thread in the '"old ecu's" section but no response yet (only posted it up there this morning)
PHat MR30- I bought the car from John Atherton about 2 years ago (he had 2 x R33 GTR's, both competing in Targa Tas in 2003 one driven (mine) by Paul Bergmann and John driving the other, the sister car of mine is probably most famous for
in "Love the Beast") and before John owned my car it was owned by John Teulan as a circuit car.
I have stripped it and rebuilt it with new built motor, fuel system, proflex/mca suspension, etc. taking it back to a circuit setup.
TO4GTR- I tried swapping around the coil packs, and even put a set of old stock ones in, same problem, I also swapped around the injectors from cylinders that I knew were working into ones that didn't (moved cyl 1,2,3 injectors into 4,5,6.) but the problem stays in #4 and #6.
I have given the ECU to Nick Ashwin (NA Motorsports/Neal Lowe) who has been really helpful, he is going to get it checked out for me.
Also, what have you guys done with Engine Speed signal for the tacho and ETS computer? I was going to try and use the Motec's ignition combiner but they no longer make the product.
Thanks again guys, I was starting to get really frustrated, I just want to race the damn thing already!
Hey all,
Spark plugs
Injector wiring
Injectors
Coil packs
Ignition module
Crank angle sensor
Thanks.
rob82 really?
I will rewire it and see how I go, I just went off the Motec diagram :blush:
Wow I think they may have stuffed that up - think about it. Firing order is 1,5,3,6,2,4
You have - (1,4) (2,5) (3,6)
Should be - (1,6) (2,5) (3,4)
So the first four firing events are correct but then your firing cylinder 4 instead of 6 - I'll let you work out what 240degrees from compression stroke is. Guess which cylinders aren't firing?
Yeah it explains everything that is going wrong, I just never thought of 2nd guessing their diagram.
Your a life saver!
I think I have done the altessa wiring correct so far ( throttle position wire and ground ) just have to do the engine speed signal to it, thats next on the to do list.
Have found the wire running from the tacho around to the ETS computer so will tap into the signal into that, just have to make up something up to convert the Motec signal into the Nissan 5v and I am hoping the tacho and ETS will work.
Most of the motec systems around the traps were wired up to retain the factory ecu to control attessa, thats about it.
bingo. I have no idea what nismoid was smoking with the "motec installed but people keep the stock ecu to run injectors" idea? Motec would be f**king useless if they couldn't control your injectors! Mine is like you described. motec controls everything, stock ecu is just there to keep attessa working easily. it can be done with it removed though but some people have never ending problems once they get rid of the stock ecu.
I swapped over the ignition wires this morning and she started up on all 6! thanks rob82.
Now I've found a rear half moon cam cover plug oil leak and a turbo water fitting leaking :laugh: so its back in pieces again.
For the guys running the Motec stand alone, what did you do about the tachometer/attessa signal?
Thanks again!
Thanks again!
Good to see you got it sorted mate. well done to Rob for figuring that out.
Re the Attesa etc - that's what I DID leave my stock ECU in for. Motec runs all fuel/ignition and engine requirements, left ECU to take care of anything else.
  • 4 weeks later...
Cameron, how did you go with this? Looking to tidy up and remove the std ECU myself. Attessa only needs a TPS signal does it not? And Motec can drive the tacho directly?
I've only just started to look into it - anything else to look out for do you know?
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
