With the limited space you have why not go with a water to air intercooler? the piping will be even shorter than stock if you can fit the stock exhaust manifold. You could place the intercooler right over the coil packs and place the radiator in front which would only be 1" thick.
I honestly wouldn't bother with intake or exhaust manifolds, the only one worth getting would be a GTSR manifold but they go for crazy money.
If you can keep the standard turbo just highflow it, will make around 210-230 rwkw and be alot more responsive then a 25 anyways.
If you cant use the standard cooler pipes and a return flow then you might have to go a cheap front facing manifold, not sure how good they are.
Cooler size will depend on boost and power levels, if you are only aiming for around 170-180rwkw then a smaller cooler wont be a problem.
Unfortunently when putting a motor like this in a old car its going to be alot of one of fabricating, you might have to make your own cooler pipes and muck around with different coolers till something fits.
On another note are you upgrading the fuel lines? I would hate to think how small and inadequate the fuel lines on the car would be.
I think that by switching the hot and cold pipes from my dodgey picture on the previous page, and running the hot pipe under the front of the harmonic balancer into the RHS of the intercooler, I'll get away with it without too much trouble, and without running that much out of the ordinary (as when compared to a Skyline). I figure the closer it resembles a Skyline under the bonnet, they better it's going to work.
Lines will be updated to 8mm braided versions. OEM stuff is plastic, and I really doubt it's good for the pressure of a late-model EFI system. They're also probably 35 years old! Several good reasons to do away with them.
A cooler like this might work better? Less piping also?
I had a good poke around the front of the car the other day with an aerosol can (67mm diameter) and because of the location of the front subframe, I can't actually fit anything on the bottom side of the front stone tray/radiator plenum area. Well, not without butchering the stone-tray and completely destroying it's sleeper appeal. Everything is a compromise... :/
Why not start with a piece of 4" and flatten it out? Need only be about an inch high to offer the same flow area as 2.5" round.
That's not a bad idea. It would slightly affect the airflow by a localised creating a low-pressure area though I think.
I think I'm just going to have a bit of fiddle with it, and see exactly what I can and can't do. Looking at it will only do so much...
I wouldn't stress too much about that. I'm not even sure what you mean by it. (My profession involves flow in pipework, so I know what causes low pressure, when it is a problem and when it isn't a problem, and I'm not sure why you'd think there'd be low pressure in there or why it would be a problem. But nevertheless, let's continue on with my further thoughts).
Logically, if you squash a bit of 4" down until it is completely flat, then there is no flow area inside it at all, and when you leave it iround it has the maximum flow area. So at some point of squashing it down to a float oval it will have a similar area to a 2.5" pipe. That's when it is about 1" high and 5" wide (if it is rectangular, which it won't be, but close enough). Now this squashed pipe has the same flow area as the 2.5" pipe, but it has a lot more circumference (exactly as much as the original 4" pipe) - so it will have more pressure drop along its length than 2.5" pipe would. But that's not a problem - it only has to be 500mm long to go from one side of the engine bay to the other. The hassle will be to merge a bit of 2.5" pipe into one end and out the other without whatever join you have being a flow nightmare. I suspect that you'l have to look at using a 2.5" to 4" cone and try to blend it out that way. If you get desperate to see what I mean in pictures, I'll have to sketch something and upload a photo of it.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
