ok guys i've got an xf throttle body on my plenum with the auto rb30 TPS (yes i've done the metal plate mod) when the throttle is wide open it isn't getting 100% reading on my hand controller. when its closed it reads around 2-4 when wide open only goes to around 31. i've even tried adjusting the TPS by undoing the screws & moving it in different positions but still wont get a good reading... kinda seem like the D shaft from the throttle body that spins the TPS to give the reading isn't spinning round enough...
could i have the wrong xf throttle body?
cheers
https://www.sau.com.au/forums/topic/373687-xf-throttle-body-tps-question/
If you have a greddy mani, a vh45 90mm tb bolts straight on.
You can bolt the stock tps to it aswell.
J.
i was just looking at some of them. i dont have a greddy mani tho. does the fx throttle body have the same 4 bolt pattern on each of them???
Ok I've put my mates stock rb30 throttle body & tps on to check if it's works correctly but when i set the tps to 0 then open the throttle fully it's only reading up to 50% on my wolf hand controller. Is there any way to set 0 when it shut then 100 when it's WOT full throttle??? Because I can't think of anything else to do...
Cheers
Cheers
Yeah as guilt just posted you need to calibrate the tps travel and voltage to the ecu's end points.
So pretty much my tuner hasn't set it right from the start when I got it tuned yeah?
I called them last week & they said I need to get the tps working correctly before they can tune it, but it's never worked right after I got it tuned anyways...
Can they defiantly calibrate it via the ecu? In other words set 0 then 100 yeah???
Cheers guys
Yes you can set the limits in the ECU, eg flatten the accelerator and see what volts it gives, this is your max volts, then close the throttle and see what the volts are, this is your min voltage eg your limits. Should be very easy to do this.
Edited by Rolls
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
