hey guys,
done a spark plug change before my tune on monday and found number 3 cylinder plug is alot more carboned up that the rest
idle has been a little rough, thinking maybe a bad flowing injector??
any comments appreciated (hopefully not to bad)
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/
Had a talk with my tuner today and going to pull my injectors and get them cleaned and flow tested. If that doesn't work, them compression test, injectors are 15 years old now so won't hurt anyway
Check the AFRs again after they've been cleaned - you may have another 25% flow!
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/#findComment-5962995
Had injectors cleaned and flow tested today. No 3 came back as flowing 10 percent more at idle than the other five.
Now looking for a new set of injectors. Anyone know of a good place to buy them. After 550cc
Hehe - so you're not going to put the highflow injector in no. 6?
IIRC the pfc can trim pulse width per injector and some ppl use that to bump up the duty on no. 6 which leans out a bit because the plenum shape encourages higher flow on that cylinder.
Maybe all this is a bit too much of a hack tho - 10% is a lot.
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/#findComment-5969327
seriously put in ID1000's, probably run better than most 555cc injectors out there and gives you scope to run E85 or any other myriad of fuels.
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/#findComment-5969711
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
    • Not a huge update because still waiting for some fittings for the intake. But I did corner weigh the car, its enough to make a GTR driver cry at 1163kg (race ready except no fuel)  Sorry about the terrible pics but I think they are readable With 70kg driver
