hey guys,
done a spark plug change before my tune on monday and found number 3 cylinder plug is alot more carboned up that the rest
idle has been a little rough, thinking maybe a bad flowing injector??
any comments appreciated (hopefully not to bad)
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/
Had a talk with my tuner today and going to pull my injectors and get them cleaned and flow tested. If that doesn't work, them compression test, injectors are 15 years old now so won't hurt anyway
Check the AFRs again after they've been cleaned - you may have another 25% flow!
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/#findComment-5962995
Had injectors cleaned and flow tested today. No 3 came back as flowing 10 percent more at idle than the other five.
Now looking for a new set of injectors. Anyone know of a good place to buy them. After 550cc
Hehe - so you're not going to put the highflow injector in no. 6?
IIRC the pfc can trim pulse width per injector and some ppl use that to bump up the duty on no. 6 which leans out a bit because the plenum shape encourages higher flow on that cylinder.
Maybe all this is a bit too much of a hack tho - 10% is a lot.
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/#findComment-5969327
seriously put in ID1000's, probably run better than most 555cc injectors out there and gives you scope to run E85 or any other myriad of fuels.
https://www.sau.com.au/forums/topic/373695-sparkplug-gurus/#findComment-5969711
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
