Hi all,
Ive been searching for more power from my r33 with basic mods such as 3” exhaust, fmic, pod etc. My Tuner has recommended the ViPEC ECU with a tune plus the needed upgrade of a new fuel pump which is old and warn. Plus a boost increase from 0.7bar – 0.9bar.
The quote was for around 3.5k I just want more power out of my car, I know im not going to go get bigger injectors or a bigger turbo is this really worth it – will I notice? Is it reliable? What kind of power will I expect (kw/HP)?
https://www.sau.com.au/forums/topic/373705-vipec-ecu/
Hi all,
Ive been searching for more power from my r33 with basic mods such as 3" exhaust, fmic, pod etc. My Tuner has recommended the ViPEC ECU with a tune plus the needed upgrade of a new fuel pump which is old and warn. Plus a boost increase from 0.7bar – 0.9bar.
Is that including the ViPEC and the fuel pump? If so, that's not a bad price. You might be able to go a bit cheaper if you sourced the parts from elsewhere. Or you could try to find a secondhand Power FC from somewhere, but I've always preferred to use whatever ECU my tuner recommends.
You will notice a difference though, it's definitely worth it.
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5961454
Yeah mate that price is every thing fuel pump, ecu, tune & installation.
But before i shell out 3.5k i just wanted to know will the power be noticeable enough to justify the price/ make me a happy man haha
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5961479
Well that depends on your expectations.
My ECU is still one of my favourite mods that I've done to my car, simply because of the difference it made to driveablity and my fuel economy. It may not give you another 100rwhp, but it gives you a bit more (especially if you're increasing the boost a bit) and it makes what you already have feel a lot better to drive.
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5961519
If you arent going to be upgrading the turbo/injectors in the future, i wouldnt bother spending all that money just for the sake of a few rwkw and a better top end curve. On the other hand the vipec v44 is a good ecu and has some cool racing features (anti lag, launch control, flat shift).
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5961588
Great Ecu (LINK G4 as its also known by the original manufacturer) it will allow scope for any mods in the future, if your not going all out it would be a wiser investment to buy a PFC as you will save about 1500 yet make the same power and have the same driveability.
Even the new adaptronic plug in select ecu would be a good investment for basic mods.
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5961606
As you have a Neo engine you could get a Nistune chip and get much the same results. You will not really get the benefits of the Vipec over the Nistune if you are not planning to upgrade the turbo etc. You should probably still get a new fuel pump as an insurance against failure.
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5961633
When did he say he has a Neo engine????
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5961922
r33 non neo.
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5962001
you can pick up a Second hand PFC for around 1000$..but before you do anything just replace your fuel pump (and filter if its old) and maybe get your injectors cleaned, this alone can make a huge difference, especially if your old ones are shagged..
Unless you got money to burn I wouldnt bother with that Vipec mate
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5962270
I disagree.. Go an pay to get the vipec and the fuel pump... Dont go half assed about shit an get a nistune, Pfc, safc etc... Vipec is one of the best ecu's on the market..
Because in the end you end up wanting more, then you'll start changing this, then changing that.. Take my advice an buy the vipec ecu, you cant go wrong...
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5962291
did the quote come with a price break-down? ie, what the ecu component is worth?
you might find getting a Link G4 from NZ is cheaper than the aussie G4
but definitely have a look in the for sale section for second hand PFC's
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5962393
Sorry must have dreamed the bit about the GTT
Still think Nistune with an appropriate ecu swap is the best value for the OP but Link from NZ is NZ$1895 so even with a temp sensor and postage it will be well under $2K
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5962552
Yes it did the vipec ecu was quoted at $1800.
how many hours is the car usually on the dyno for ive been quoted 6 hours? does that sound about right ive never had a tune before.
https://www.sau.com.au/forums/topic/373705-vipec-ecu/#findComment-5962850
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
