Help Plz R34 Gtr Vspec
hi guys im new to skylines australia so here it gose i brought a r34 gtr vspec on the weekend a 99 model with 56000km on her so i took her for a drive and all went well but i took the car for a very long drive i notice the turbos had a does and the blow off valves werent relesin but i got that fixed...
now i went to work the drive was fine on the way home i gave it a boot and white smoke came out of the exhaust alot i say it dosnt blow smoke on idel or free reving just under boost i pulled the air filters off and it the front pipes of the turbos there was oil and in the intercooler pipes alot of it say 300ml just wondering what to do if any1 thinks its turbos or bottom end or head im un sure its only white smoke not blue so i asume its turbos thanks for reading and look forward to the replies thanks daniel
PS if it is the turbo's what is your apinion what to upgrade to gt2860 or hks ss or trust t517z or go a single let me know what you have done to ur car also mine has a tripple plate hks clutch hks 3" dumps into 4" exhaust coil overs thats all thanks alot guys
i think it dose but im in gold coast also i checked the turbos have alsot of sharft play if i clean out all the intercooler and pipes and turbos and hook a catch can up to the rocker cover & if the catch can fills up that would mean the engine is that right?? and if it dosnt it will mean the turbos
It could be anything from a blocked crancase breather to a completely farked engine.
If it's from a car yard, is there a statutory warranty applicable?
Mate if its got warranty use the warranty and dont touch anythign yourself....All you might do is stuff yourself over with the warranty.
The company should nominate a workshop for you to take it too and get them to fix it completely. Also note everything down thats wrong, when you called them etc etc
You bought from Sydney but you are on Gold Coast making it too difficult to return the car for warranty?
You need to take it to a mechanic who is familiar with Skylines.
He shouldnt do this ATM...it will void his warranty. He should contact the place purchased and ask what they want him to do... They will hopefully nominate a workshop uphere for him to take it too.... ALthough this may seem like the shit option. It means that his warranty will be honoured and it could save him thousands (possibly ten thousand if the motors dead).
I would use the warranty and remove your name and other personal details from this thread just in case the dealer is on here and voids it.
We all know you just checked a few things and cleaned, you didnt screw with anything so maybe get a moderator to remove some details of where you got it from?
All the best mate
hi guys they dont want a bar of it they think i wound the boost up and blew i as i know i didnt were should i go from here i have taken it to nissan they checked it all out they said engine is all good but the turbos need replacing what turbos would you recomend thanks alot guys for your help sorry about the hasstle
sucks to hear mate, i dont think warranties cover wear and tear parts like turbos. Plenty of threads on here about turbo upgrades, if your like me and want a nice streeter then just get yours rebuilt from a company like gcg or gt-ss or 2860-7.
do a quick search and u will find more info then you can read.
cheers mate
yer thanks i found a brand new set of Genuine garret 2871r dash 10 turbo's with acuators for $2400 are they any good or to laggy just wondering i also have a arvc in it will i need a power fc for this turbo upgrade or just my standed stuff with arvc thanks alot guys for your help
cheers mate
u want (-9 or -7) if u happy to run around 300-320kw without forging ya motor
-10 is not suitable as its very laggy on 26
as a fellow R34 GTR owner and member of SAU QLD, i can not recommend highly enough Dan from ERD
he has done LOT of GTR's and is a Top bloke, who does not over charge jus cos it GTR ... believe me i know !!
I would say just take the car to ERD "not too far from GC anyway" and get his professional opinion
ERD - http://www.erd.com.au/
C,
Kushil
 Share
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
