Just trying to find out if there are more than one rev limit addresses in the RB20DET (ECCS). The reason I ask is that I decided to put my rev limiter up to 8200 and it hasn't change at all.
Ive always been under the impression that it was set at 7800 and was found at 7FB4(address line) in the eprom.
Any ideas guys?
https://www.sau.com.au/forums/topic/37375-rb20-ecu-addressing-qs/
Well if anyone is interested I did end up finding what the second address is for the rev limiter. Ok address one is 7fb4(and this value is 9C in hex which ends up being 7800rpm) and the second is 7f8b (and his value is 97 in hex which ends up being 7550rpm)
I tested both these values and these seem correct.
Oh would anybody be interested in me posting up some stock binary files for a couple of cars. I have a R32gtr and an R32 gts-t stock bin file plus a few others.
Firstly you need to get you ecu's eprom removed and a 28pin socket put into its place so you can insert/remove the eprom easily. If you aren't to confident to do this just take it to a tv repair shop and get them to do it for a small cost.
Secondly you need an eprom reader/writer that will allow you to write new eproms. Theres a good one that you can buy on www.batronix.com that uses the pc usb port. Very good as you dont need a power source for it. They give you the software for it too.
Thirdly you need the software that alows you to modify the eproms data so you can change the rev limits/ fuel cuts / fuel maps / timing maps etc. I use the romeditor software which is located at www.925style.com/editor_direct.html. You need to download the address file for you specific car etc.
I'll get my work laptop online later today and I'll post up the bin files of the RB20DET and the RB26DETT with the adress file for the RB20DET which I had to modify to allow for the adjustment of second rev limiter and a few othe minor things.
I'm guessing you have an R32 GTS-t ?
I'll post up URL of a site that is dedicated to the 300ZX Z32 and it has a very in depth explaiation of the ecu. The same basic principals apply to the R32 GTR/GTS-T. I just don't know the url off the top of my head but is bookmarked on the work laptop.
That zed site is
http://cherrypicker.tripod.com/turboupgrad...0dett/id10.html
The HCR32_256_Rev2.zip is the address file revised for the RB20DET(R32).
The Bnr32.zip is the address file for the R32 GTR.
R32 GTS-T ECCS RB20DETStock.zip is the stock bin file I read from my eeprom and is from a 92 R32 GTS-t type M.
R32 GTR RB26DETT STOCK.zip is the stock bin file for the R32 GTR.
I'll post up some info on how to use romeditor and the basic theory behing the nissan ecu's at a later date when I get the chance.
Yeah that file @ http://www.boostcruising.com/silvia/romstu...uff/romedit.zip is the same as the one I have. Thanx StraightSix.
I just fixed up my post on the files so you all know what the files are. I didn't explain it too well the first time.
Something I was wondering about . . . would a good approach be to tune with piggybacks and then transfer that tune to a chip? Or would the fact that the piggybacks can only give you values that are already in the factory chip be too limiting?
Oh and RD would you object if I reposted those files on GTRCanada?
Cheers
Jason
Piggy back computers are really limited to what the ecu can do in the end, well from what I understand anyway. I would say it would be just as easy to start from the ecu chip rather than to transfere from a piggy back.
As for the files thats fine I don't mind at all.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
