Hi every one I'm looking for answers on intercooler piping for a rb20 with a top mount turbo. Will I need a front facing plumum or is there any other way. I can make the plenum that's no worries but I would like to keep the stock item as it would have no worries with my power needs.
your stock cooler pipng (crossover pipe) will be directly where your high mount turbo will sit. so you'll need some custom piping. check out roys crossover pipe in the build up forum, but of course something like that will only work if you have a front mount...
Hey guys sorry for not replying sooner I tried the piping that way and wasn't really happy with it so I tool it to myself to make a plenum and I'm hoping it will work what I did was remove top half of the stock plenum and blocked it off and filled it with water to c how many liters of water it held then I fabricated a plenum to the same size and capacity being a fabricator myself was easy. The plenum is made from 3 mm ally with a 6 mm base to connect to the bottom runners it holds 4.1 liters a bit more then stock but if to big I'll just make it smaller best part of the plenum I can still use stock accelerator cable and most of the fittings. Now my only thing I'm wondering about the air regulator is it needed or can I just get rid of it? I'll post a photo of how it looks. The car is going on the dyno soon just need the new fuel pump which is coming on tuesday and tell you if I lost or made power. Before the plenum and top mount the car made 187 kw with 12.5 pound with a rb20 exhaust housing and vg30 compressor wheel and housing please let me know about the regulator
  • 3 weeks later...
  • 4 weeks later...
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
