Hey guys! Just a quick question.
After my last stage of installments my r33 gtst is now running over 220rwkw, however im having all sorts of trouble putting that power to the ground and before I go for any more power i think it needs to be addressed.
What suspension/handling upgrades are there out there that I should be looking at for my rb25?
I know a good set of tires is an obvious reason and also a reduction in tire pressure also helps but what other ways are there so I can keep it in a straight line? At the moment under full throttle and it cannot hold grip until the beginning of third :/
Cheers!!
https://www.sau.com.au/forums/topic/373754-traction/
After some quick research I have compiled a list of things that would help address this issue and improve overall suspension. What do you guys think? Have I missed anything?
Decent tires (Kuhmo Ku36 for street use)
Front and Rear Coilovers (monovalve)
Castor rods
Front & Rear Camber arms
Adj Tie rod ends
Pineapples
Nolathane Control upper arm inner bushes
Nolathane radius rod adj bushes
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5962711
Half that list won't actually do anything for straight line traction.
On stock suspension you really should not be having traction issues if you have good tyres and a good alignment. Do those first before doing the rest.
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5962926
As said above what you listed will help grip or drift where corners are involvrd straightline traction almost goes oposite with softer suspension zettings working better. The adj arms are only used to correct or customise alighnment settings wben you change the geometry for example lowering it.
So just get the tyres and you should find that solves your problem espcially at 220 kw
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5963004
ahhh!
i am also having the same problem, just found this post while browsing so i havnt done any research yet,
but im also quite confused as my rb25 is still stock just running actuator pressure (nothing over 9psi)
i can take off smoothly (ie. im not dunping the clutch) and as soon as i get the pedel to the floor the ass jumps around like a mofo, if i grab 2nd quickly it keeps spinning the tires till i grab 3rd
as far as i know all my suspension is stock, but the guy i bought it off did say that it was really low when he got it.
ill check the springs tomoro n hope it wasnt a chop job too :S
thanks for the advice ^^^^^ i now have a list to run through :D
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5964052
