hey guys reluctant sale but time to move on and save up for a house. if you are interested please pm me.
1989 chassis S13 Onevia all interior/engine/rolling fear and parts are from a 1995 180sx.
Engine
SR20det 86,000kms
Apexi ax53b70 turbo
turbotech boost tap
bosch 040
740cc nismo inj
Z32 afm
hks pod/intake
catch can
Gktech overflow
isc 52mm radiator
Au thermo fan conversion
Gktech returnflow cooler kit
justjap 1 piece dump/front
jasma 3inch twin pipe from catback into twin tip
catco highflow cat
oil cooler w/ relocation kit
apexi power fc w/ hand controller
suspension
isc coilovers 10kg fr 8kg rr
just jap swaybars with superpro bushes
front/rear strutbars
engine damper
drift pinapples
driveline
sr20det gearbox (never crunches)
Excedy 5puk heavy duty cushion button clutch
nismo 2 way diff
exterior
electronic sunroof
genuine gp sports front bar
vertex side skirts
vertex rear bar
custom cut flared and welded 50mm rear guards
180sx front
5 stud conversion (s15 brakes/hubs/rotors/lca's)
deleted spoiler holes
Aerocatch bonnet pins with keylocks
black d1r wheels
interior
carpet/dash/seats from 1995 180sx
all sound deadening removed
interior sprayed topsecret gold under carpet
Drift oil pressure, oil temp, water temp, volts gauges
Saas Boost gauge
impul gear stick
OMP dished steering wheel
Drift button
digital climate control, compressor just needs gassing
sound system
clarion 6x9 rears
pioneer 6" front
jvc headunit
not installed but have blaupunkt amp and kenwood sub would throw in for free with wiring kit
car was tuned by chequered tuning (status) made an easy 223rwkw on 16psi with more left in her, tune was done to be very fuel efficient while not running lean, was getting a little over 500k's to the tank of 98ron.
car is very reliable, Sprayed VE commodore karma metallic with purple bonnet, car is registered with 6 months rego. this car is track ready also, if u want just chuck a half cage and some buckets and u have urself a mean drift car.
after $10,000, or straight swap for a daily or swap plus cash my way only, depending on the car. car is serviced every 5000km's with anglom oil. pm me mob number if u are interested and u would like photos. cheers.
https://www.sau.com.au/forums/topic/373757-s13-onevia/
all pm's replied to, should have said in first post, interstate buyers more than welcome, u can send a mate to check out the car or get an racv/state roads check on it (at ur expense of coarse). will happily send the car by freight or even drive it to u myself and fly back home. so dont be shy.
https://www.sau.com.au/forums/topic/373757-s13-onevia/#findComment-5964066
