  • Replies 46
My transmission fluid was changed today.
I drove the car back to the office and checked the levels.
The fluid level was about an inch above the s bend on the dip stick!!!
Checked it about 3 times, so I reckon they put way too much in.:worship:
Going to have to take some fluid out tomorrow.
use the transmission cooler loop to drain it instead of taking the sump plug out.
chuck it on a hoist, have one person remove the hose and the other start the car. get the person under the car to measure how much is coming out. 1" above the H mark, 1.0-1.5L i rekon
Edited by zei20l
Thanks,
Dropped about 2 liters out and i think its still a tad on the high side.
Used the sump plug- much faster :thumbsup:.
Will check it again tomorrow.
Thanks,
Thanks,
A tad above high mark will be fine IMO. Mine ran fine with a lot more than a "tad" above the high mark for over 12 months before I changed the valve body.
did my gearbox oil on the weekend. Went with Nulon stuff. Only managed to get 6.5 litres out of it though.. took the cooler off as well. Hoped to get more than that out...
Anyways done now. Certainly feels a lot better through the gears.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
