Hi all,
wrecking a few cars, lots of parts, offers welcome.
Motor and manual box still in car (series 2) with loom and ecu $3200 complete! Test drive welcome (i need to arrange a permit so give me time) runs great, box is great (maybe a short shift, i am unsure)
Headlights (series2) $550
(series 1) $200 (both, one is great condition one foggy)
Sard injectors 700cc (used for 3 months, top feed) $350
ABS Pump and Relay $100
Reserve bottle $5
Washer bottle with pumps $10
Radiator supports $120ea
Engine bay strut brace $50
Guards $50 both (great condition, silver series 2 with GT badges)
Pink series 1 bonnet (hail damage dints) $10
Cluster with 117xxxkms $100
Petrol door and cap if needed $15
Mirrors (pink or silver) $40
Steering wheel (series 2, worn leather) $50
Seats (enuire) letting them go cheap so offer away, front has tear, rear are perfect! (series 1 and 2)
Rear vision mirrors $15ea
SONY single din head unit $30
Strd cooler with pipe $60
Strd cat $60
Diff (series 2 manual) $250 Series 1 and cradle $90
Jesus handles $10
A pillar (passenger) $10
Gear knobs $10
Centre console $50
Trims $30
Engine bay firewall insulator $10
Master cylindar complete with lines $100
Hand brake cable and lever set up $100
17inch rims $600 (pic attached) with tyres
Rotors/hubs/brakes $750
Lower control arms $80
Dash $30 (s1)
Boot lid $20
Skyline garnish $40
Tail lights $40
Rear bar $110
1 Guard $10
Side window centra pillars (carbon) $20
indicators $5
window switch arms $20
mats $10
Auto cluster $50
climate control $30
A pillars (s1) $10
brake booster and master $70
interiors bits and pieces (ASK AWAY)
Pink doors $10
pedal box $50
Located in Melbourne West (pick up prefered) can deliver some parts... THANKS!
So many more parts so email pavlides_daniela@hotmail.com
sms 0401 886 396
or PM
https://www.sau.com.au/forums/topic/373812-r33s-wrecking-series-1-and-2/
  • Replies 72
Posted Images
hey bud, definately top feed, they come off a gtr not one of these wrecks :) they're a mates but he doesnt use the net so im just helping him out. can pm u his number if you're interested? thankx
sorry boot lining is sold - that plastic bit i have but it's all cracked/broken (so hard to find good 1) if i get more il let you know though
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
