R33's Wrecking (Series 1 And 2)
Twin charging needs the supercharger to be PD. Centrifugal blowers need not apply.
Hopefully you get there one day. But, there's a lot that goes into a build that may or may not be common or even specialised knowledge. Then fabricating things that are one offs due to not being a common modification(eg, manifold and piping for twin charging). Keep in mind, most superchargers(if using that for the low end) that are turbo style have closer output to an exhaust driven turbo. Vane or roots would be better. Maybe a sequential twin setup, but generally these are scrapped on stock cars for a decent single set up.
Oh dam. Thats going to be an expensive fix. Happened to me too. Ended up needing a big single and a seqy. Now it runs just fine.
