Hi guys,
Sorry for the noob question, but I am hoping someone here can give me the answer. I have got myself the Haltech Platinum Pro ECU for my R33 GTR. It's a Plug N Play ECU, so I am assuming this means I can just take out my stock ECU (which is hooked up to a HKS Fcon Pro V piggy back btw), plugin the Haltech and go for a drive? My car pulled 310 Kw at the wheels when it was last on a dyno (this is how it came off the boat from Japan - there was no tuning involved). The car has aftermarket injectors, dump pipes, larger turbos, a larger HKS inter-cooler, pod filters and an Apexi hi flow cat. I am not a fan of piggy backs and that's reason I went for a stand alone (my mechanic also advised me to go with a stand alone).
Am I getting the whole Plug N Play concept wrong or do I need to get it properly tuned before even thinking of going out for a drive with the new ECU?
I know I am coming across as absolute noob, but I will be grateful for any any advice.
I am just excited at getting the new ECU, and hence why I am keen to put it in the car!
No you cannot go for a drive. You have the concept wrong.
Plug and Play simply means that it connects to your stock loom without modification, and works.
All it comes with a base map, that is configured for a 100% stock car only.
If you have aftermarket bits, you need to configure them within the ECU. The ECU does not know what parts you have over stock unless you tell it.
So given your modifications - Do NOT attempt to go for a drive. You must have it configured and tuned.
It's the older Silver version mate. Version 2.1 and the tuning software is all apparently in Japanese. There are only a few tuners Australia wide that can tune it (most interstate, and a couple here in Melbourne I know of).
http://1jzmerc.com/hks-faq/hardware/f-con-v-pro-silver
    • I did a bit of googling, the color MCM used was Galaxy Grey from House of Kolor. This is actually a colour I picked out about ~10+ years ago (or more). This one is a stock BMW colour, I guess over the years I figured it was smart to get an OEM colour that was pretty common for all of those sensible reasons one can think of..
    • I absolutely love having clean wheels and also totally love cleaning them. Its not as important to me to have a clean car exterior as it is to have clean wheels. So I bought a kit. I generally use different products for my wheels than anything else, so I thought I'd buy a proper kit and bucket to keep it all in. I got this one from Waxit. I also got the CQuartz wheel and plastic ceramic along with a bunch more application micro fibre pads as CQuartz never provide enough.  The kit was good, but as usual the big, long spongey thing didn't fit between my spokes, so I needed to use a detailing brush and a larger brush that I already owned (been doing this forever, the spokes on these wheels are frustrating.) I did a full clean with the wheel cleaner, it has an iron killing product in it, so I found that I could just use the cleaner and nothing else on the wheels. The tyre cleaner and handled brush were awesome. Made cleaning the tyres so easy. Once everything was clean, I decontaminated with isopropyl and applied the ceramic. Two coats. I bought 2 bottles as I have a lot of wheels to do, half of one bottle did two coats on these. The X5 has 20's so I reckon probably 3/4 on that. Then, for possibly the best part, the wheel cleaning kit comes with a tyre black applicator. But, this is possibly the greatest sponge of all time - its a great size, quite stiff and HAS A COVER! When you finish applying the black, you just put the cover back on! This is revolutionary, I normally have to try and find safe places to put my tyre black applicators as they are covered in silicone and tyre crap. Or, you use something which just falls apart. This applicator is the bee's knee's. Get one. It's worth it. The tyre black is also like a cream, its very thick but goes on really thin, its very easy to use with the applicator. Ayway, after a big clean, decontam, ceramic coat and tyre black the wheels went back on and they look awesome.   Thought I'd share.
    • Haha. Good work. I feel some of your pain because I spent a bunch of time under my car over the period too. Probably nowhere near as much as you did. My happiness is similarly improved by obtaining a desired result though. Those side skirts are.....hecking. Very unfriendly for street and hoist. Sounds to me like you've made a cart that needs to be driven up only planks/blocks at a 2 post hoist, rather than trying to get it up onto a 4 poster. It's very pretty, by the way. Somewhat reminiscent of Marty's squid ink on SuperGramps - at least in the photos.
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
