I have one of those 30% more clamping purple clutches..
It has been pretty damn good and lasted almost 2 years of hard launching & gear changes. It has always slipped a little easier than expected however the front seal of my gearbox does seep a little oil so I assume this is the cause.
  • Replies 91
  • 1 month later...
I put an exedy Twin Plate (new) clutch with lightened flywheel in my 33GTR yesterday. My old Heavy Duty Exedy Single was stuffed!!! had nothing at all left on it when we got it out... value for money on that clutch :D
The new twin plate is great from what i have driven so far, no rattling (yet, will happen when it gets a bit worn i think)... bites hard, bit heavier under the foot, but still very drivable.. I'm happy with it, makes my car feel tougher...
Nismo use the same exedy twin i put in...
how can a twin plate clutch be easy to drive on the street as a daily driver?
Simplistically a single plate clutch, to hold say 500 bhp, has to have a much higher clamping pressure than a twin plate to hold the same 500 bhp. The reason is that there is twice as much surface (friction) area to transfer the torque in a twin plate. So if you have found other twin plates harder to drive then that would be because;
1. Maybe they are set up to handle much greater torque loadings than the single platers you are comparing them to
2. They are set up to suite a particular requirement, not what they are being used for ie; quick change, no slip competition
3. They do take some time to get used to, with twice the friction area they are quite different in feel
4. There are types of twin plates (solid centre, puck, ceramic, cermatallic etc) just like there are different types of single plates. Not one type suites all.
The reality is once you get to a certian power level you really have no choice, a multiplate clutch is a must. So the best you can do is choose the one that suites your own requirements and preferences. :D
good info here...
i need some input on this...i installed an orc twin plate
on my bro's s14...straight from the start when you clutch in
there is a real loud continues rattle...i didnt think much of this
and thought it was just caues its a multiplate clutch, am i right?
big problem is...it wont go into gear now.. after the install it was
fine, hard to get into first and reverse...then it loosened up after
about 500k's and now it wont go into gear... engine off no probs
but no luck when on..what could be causing this?
i've noticed that the 'rattling' when clutched in is not as noisy as
before too.. im thinking somehow the fork as shifted on the bearing
holder or something...
final question is when you guys installed your multiplate clutches
did you need to machine the bearing holder so that the bearing sits
further back from that of the factory position? to compensate for the
extra width of the new clutch?
any help would be GREATLY appreciated...
I'm going for a 3000lb 5 puck ceramic clutch in my GTR. A mate is running one and it seems to be up to the job so far in his GTR. it's a bit bitey but so was the one in my GTS-t so i'm use to it. cost me about $650, was going to install it myself but I'm kinda tight for time so I'll prob get it done at the mechanics along with getting the flywheel machined.
i just got the exedy single plate organic sports... driven about 400kms and bites quite good... but i still have trouble nudging forward and reversing as it shudders... not sure how long before this wears off.
I have the same and it does it, I'm not sure what causes it, but the simple and easy answer is not to ride the clutch.
Lunatic Dancer: Exedy Twin Plate....
no rattles/noises (yet, will probably get them when its worn a bit)
In fact, it actually fixed a noise which i thought was my gear box...
When in neutral, clutch out (engaged) it made a sound like something spinning, i thought it was just worn gears on my gearbox....when pushing the clutch in (disengage) it went away... after changing my clutch, that sound has totally gone....
Thinking of getting the Nismo coppermix kit from Nengun ~400ps $1600 delivered comes with pressure and clutch plates, thrust bearing and lightenened flywheel. OR
From Taka Kaira, Ogura Kit ~400ps also $1600 delivered with above parts.
Anyone heard any good stuff on these?
Duncan: Yes we changed my thrust bearing with a new one when we did it, the old one seemed fine tho (was a bit black from clutch dust, but spinning fine)....
As for the clutchs from overseas - be careful about 'delivered' prices... with a box that heavy and that big, you may get slammed with customs tax
Sydneykid...
Sydneykid...
Yep that's right, but not all multi plate clutches rattle. Some have anti rattle springs, they are silent just like a single plate.
Since there are 4 friction surfaces, they wear in a lot compared to a single plate with 2 friction surfaces. So they need adjusting, otherwise there is not enough movement to dissengage the clutch. Nissans don't have adjustable rods, they use a byspass in the slave cylinder to take up the slack caused by normal wear. Refer below.
Unlikely, it is usually all or nothing when it comes to fork movement.
No, but I have never done an S14 (or an S13 or an S15) for that matter. There are however a number of different Nissan fork pivots, some are longer than others. You need to choose the right one to position the clutch fork in the right place.
It sounds to me like you might have had the wrong fork pivot (too long) and that's why you had to machine the thrust holder. So how to fix it? Well, I would try a longer rod, that will at least eliminate the lack of travel question without removing the gearbox. You could weld a short piece of rod onto the standard rod or find a slightly longer Nissan rod from a different model. You used to be able to buy adjustable rods, do a bit of shopping around.
Hope that helps. :)
PS; it is not unusual for R32s' to break the pivot ball, I don't know whether this applies to S14's. You can easily check by looking in the fork hole with a torch.
SK,
Some multi plate clutches require a shortened thrust bearing carrier. ORC and HKS are the two brands i witnessed this with. Nissan make different length carriers as well.
I've never altered my pivot points as it creates more complications as you've mentioned.
Lunatic Dancer,
I think you may have mentioned out too much from the carrier which is ending up reducing your throw.
Did you try giving the system a good bleed...?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
