I put my car on the dyno at Rotomotion on Friday to get my tune checked. I was/am using an innovate wideband that is about 3 months old. Anyway there was a 5 point difference between my wideband and the one at the dyno. Mine read 12.0 to 1 at wot. The dyno read 12.5 at wot. I got my tune adjusted accordingly. Scored and extra 5 rwhp as well. Anyway just putting it out there. It would suck to melt something cos of trusting a $260 sensor/gauge.
https://www.sau.com.au/forums/topic/373886-wideband-discrepency/
I have tuned most of it myself over the last few months. I was still at work while the car was being tuned. I didn't get to see any logging when I picked it up so I'm pretty sure they just had a look at it and changed the bits I asked them to. I got it to 247 rwhp with the stock turbo at 12 psi and they found the extra 5 rwhp by adding 1 degree to load 16.
leaning out the tune under high load/boost wont really improve fuel economy. You want to have the AFR's there Safe rather then economical
The economy comes from your lean cruise points, so at constant 60km/h, 80km/h, 100km/h etc. Having your own wideband + tuning software makes this easy and you can get it running pretty good
My best friend used to tune my car for me and he said my car actually responded better to having a bit more fuel chucked in when boosting
[quote name='89CAL' timestamp='1313234034' post='5964918'
Flame takes up more space in the exhaust, more fuel equals more flame equals more spool, that's how antilag works. If you boost up on your cold start map you will see this very well.
When I said lean it out I only meant from the 11.5 it reads now to 12. Safe is good tho. On the subject of spooling up early its gotta be lean to get the exhaust gas hot and expanded to create more volume of gas to turn the exhaust wheel. Having the timing right for spool up is equally as important. Enough but not too much or it will run rich. Cars will have more power leaner but run a lot hotter. Then you reach a point where you lose power cos there aint enough fuel there. However that point is far beyond safe under high load. Don't go there! Running lean (16.5-1)and high timing (30-39) at light load on my car is optimal as I use bugger all fuel and have the engine ready to spool early. As soon as it spools and gets up in the revs (over about 4k) you gotta cool it off with the extra fuel. Antilag is not like spooling up in the normal rev range. You use stacks more fuel and completely different timing to achieve it. Phew... back to movies and beer :thumbsup:
You don't necessarily gain more power by running it right on the edge (12:1 or so). It was discuss not long ago that the japs run 10:1 AFR's and more timing to get just as much or more power as tuning done over here with leaner mixtures and less timing.
I think 16.5:1 is a bit lean for the lean cruise AFR's personally. But that's more up to you
If the tuner is used to using a sensor in the tail pipe he should be able to do a good job but both tuners i use will put another bung in the down pipe for their sensor if there is not a spare already, Just takes a few minutes and then its there for next time.
I have thought of running super rich and more timing but haven't tried it yet. Its a pity the weather is wet or I'd have a go today. I have found though that the amount of fuel used between 12 to 1 and 11 to 1 is very noticable. I can get around 650 ks a tank running at lean at light load and obviously heaps less on boost. I have found that anything past 16.5 to 1 the car surges, although most of the time in normal driving it is under that. 16.5 is just when my foot is still on the throttle at 60kph.
12.5 is safe on a RB... when tuned right... even seen 13's on a 500hp endurance engine so 12's is nowhere near the edge.
To the OP 0.5 is often the approx difference from dump to tailpipe depending on cat and dyno pickup design at the tip.
So Trent, do you reckon that 12.5 is fine for mine? Most of the RB dyno sheets I have seen are at 12 to 1. I figure that seeing as it is only driven on the street and isn't at wot for very long it wont get too hot. I haven't got a pyrometer so I cant really tell tho. In saying that I still have a stock turbo so I dont want to spit the exhaust wheel out just yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
