just installed a FMIC last week, noticed that the fan behind it isnt running when car is idling, or with a little rev.
not sure if it was runnign before either, never took much notice of it
ive attached a picture of the fan im talking about
wondering if its a thermo related fan only runnign when needed to, or if its supposed to run all the time ie mine is stuffed.
im no car genius so i dont even know what the fan is for.
ive tried the car idling with aircon, without aircon, and both with a little rev, still no movement.
any help on this would be great so i know how to fix this issue or if its a non issue.
thanks
https://www.sau.com.au/forums/topic/373953-r34-gtt-s2-fan-behind-fmic/
I believe that fan only kicks in when your engine is above a certain temperature AND you have your A/C on.
Thats how mine has always been anyway...
EDIT: Before I got my A/C repaired I used to drive around windows down in 40C+ weather (not pleasant :down:) & I never noticed it spinning, however once I got the A/C fixed I started noticing it kicking in at certain times when driving with A/C on.
Usually when I'm idling at the lights & the engine temperature goes up by a couple of degrees.
Edited by Mayuri Krab
AND if u decide to get the big ass plazmaman intercooler you will need to remove this fan and replace it with an aftermarket one as the stupid thing is about 2 inches too thick :P
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
