my old man is moving to australia at the end of the year and is planning to bring his +4 morgan and triumph tr3 over with him,
whats the go with how to get them over here to brisbane and who are the best companies to do so? they are both LHD one is in running condition the other needs an overhaul.
any help would be great.
cheers
riley
https://www.sau.com.au/forums/topic/373957-importing-from-canada/
Both will be fine to import, and can also be registered LHD anywhere in Australia. If you're old man wants help with it, tell him to drop me a line.
he's right about the triumph, but the morgan yes its an old car but its the only hand made( completely) car in the world even though the year model is in the 60's it was manufactured in 1994.
the morgans chassis is also made of wood lol is that going to be a problem to import?
and do u have a rough price it would cost to ship them both at the same time? like a bundle deal
+1 it is flat as at the moment ( Oz market is not that much better.)
just found out that its only a problem to import raw wood, so the morgan should be fine ( minus the obvious clean it needs before shipping)
iron chef any idea what the price would be, and is it cheaper to import two than just one?
if you import 2 cars at the same time there is potential to save a couple hundred dollars here n there.. but ultimately no it isn't cheaper because most of it is government charges and labour...
as for the wood thing - please get clued up on modified pre 89 imports.
it basically is there to stop people like hot rodders from bringing in:
Model T Ford w/ chopped roof and 15in wide rear wheels with a custom tub rear, with an LS7 engine conversion... that has been built onto the chassis of a chrysler PT cruiser in 2007.
^^^ it was to close the loophole that gave potential importers the ability to import "pre 89" cars with them being pre 89 purely on face value.
however in the wake... it's affected an entire market of people unable to import their cars. I should also note that import approval is still given the "yes" or "no" approval by the same people and REALISTICALLY not much has changed.
however you mentioned something something something built the car out of wood because you thought it was cool to be Armish in 1994 - :P
in that example its best to speak to australias dept of transport about it.. just in case. would hate to see youre claptraption be declined import approval due to no homework being done..
..that's all i was saying :)
Shoot me an email mate (see my sig) and we'll get you some prices. The wood won't be a problem. To answer your last question, probably not ;)
ok lets clear sumthin up.......the amish were cool in 1994 and still are.....i wish i was amish.....churnin butter and stuff...................and the chassis is wood cause its lighter and easier to replace than steel. dont worry i hang shit to my old man about owning a car made of wood. thanks for the info. and iron chef ill get the details and try to get my old man to sort a date and stuff out with u
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
