Ive found a whole bunch of threads about cleaning the outside and what not but I need to clean the inside, there is a fair bit of shit(due to them being sitting for so long with no bulbs/caps) inside and I wanna clean it up.
What works to get the light open? Wack it in the oven for 15mins on 100c? Anyone done this before, let me know!
https://www.sau.com.au/forums/topic/373962-pull-apart-r33-tail-light-series-2/
dont go 100deg for 15 min...you may warp the plastic lens....try for 7-8mins and see if they get loose...if they do get a bit loose and need a bit more try for 2 or 3 more mins at a time. I know thats not the answer your after but I dont want you destroying your lights.
I believe the same method should work for the front lights too. f**king shit, I just polished up one of the lights and when sanding must have got some water in the back and now there is condensation building up. Hope that water was clean or Ill be ripping faces off if I see dried up marks.
With the condensation though, what I would do rather than pull the light apart is blow some air into it with the two light caps off at the back or chuck a hair dryer in the rear. Ill check it out tomorrow. its my other headlight which has a dead bug and other shit in it I need to clean up.
Condensation will only form if the light is not sealed, so if you are running HID's and you modded the back of your caps to suit, seal them up. That shit is f**king annoying.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
