BloodBath Posted August 14, 2011 Share Posted August 14, 2011 I have a Nissan 240sx with an RB25DET. It has an AEM Stand alone EMS. I have had it lean under boost and never seen Knock... I was wondering the procedure for testing the knock sensor circuit before I put in race gas and start adding timing. Thanks Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/ Share on other sites More sharing options...
89CAL Posted August 14, 2011 Share Posted August 14, 2011 AFAIK they have to be removed and tested with an oscilliscope, but you must know the frequency at which the sensors register knock as well Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5965471 Share on other sites More sharing options...
Rolls Posted August 14, 2011 Share Posted August 14, 2011 Buy knock ears, the only 100% reliable way to tune a car and listen for knock. Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5965539 Share on other sites More sharing options...
JonnoHR31 Posted August 14, 2011 Share Posted August 14, 2011 lean mixtures wont always induce knock, timing has a much bigger effect. Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5965587 Share on other sites More sharing options...
Room42 Posted August 14, 2011 Share Posted August 14, 2011 lean mixtures wont always induce knock, timing has a much bigger effect. Exactly right. Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5965617 Share on other sites More sharing options...
Rolls Posted August 14, 2011 Share Posted August 14, 2011 lean mixtures wont always induce knock, timing has a much bigger effect. Especially when it is winter and the temps are cool. Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5965703 Share on other sites More sharing options...
BloodBath Posted August 14, 2011 Author Share Posted August 14, 2011 thanks guys. It was very hot out side, like 105 and 12.8 afr, stock turbo 12 psi. didnt register any knock. I have changed my intake air calibration since then. Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5966561 Share on other sites More sharing options...
STATUS Posted August 15, 2011 Share Posted August 15, 2011 I doubt the EMS is connected to the knock sensors.... Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5967049 Share on other sites More sharing options...
BloodBath Posted August 15, 2011 Author Share Posted August 15, 2011 Its gotta be. its plug and play. Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5968428 Share on other sites More sharing options...
mattis96 Posted August 15, 2011 Share Posted August 15, 2011 Aren't the haltechs plug and play and they don't use the knock sensors as well? Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5968449 Share on other sites More sharing options...
STATUS Posted August 16, 2011 Share Posted August 16, 2011 Its gotta be. its plug and play. Most plug and play dont use the knock sensors, what model ems? Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5969391 Share on other sites More sharing options...
BloodBath Posted August 16, 2011 Author Share Posted August 16, 2011 its an aem ems, series 2 for the r33 rb25. It has knock charts on the program on my laptop. it just always reads 0. Ill mess with it and see if I can get a fast stock turbo video up for you guys. I wish I was playing around at sea level!!! John Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5970370 Share on other sites More sharing options...
Beer Baron Posted August 17, 2011 Share Posted August 17, 2011 lol. it always read 0.... guess what that means......... Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5970931 Share on other sites More sharing options...
STATUS Posted August 17, 2011 Share Posted August 17, 2011 its an aem ems, series 2 for the r33 rb25. It has knock charts on the program on my laptop. it just always reads 0. Ill mess with it and see if I can get a fast stock turbo video up for you guys. I wish I was playing around at sea level!!! John Sorry here in AUS we have AEM stinger and motorsport ecu's which are different from the US based AEM version 2.. in fact they are not even similar. I JUST NOTICED your location is USA or similar. The AEM Version 2 is an AWESOME ecu and we tune a fair few turbo hondas and some bigger hp supra stuff with them, YES it does have knock control and feedback engines but ive not had a play with one in a R33, it worked awesome on a turbo S2000 we did. I have a feeling it wont be compatible with the std RB25 sensors, but send Aem an enquiry as to whether ot not they are supported as its a great feature in the Version II. Aem Version II http://www.importpartspro.com/306621r33rb26dett.html our Local AEM product range: http://www.enginemanagement.com.au/product_info.php?products_id=107 Its kinda like comparing apples to oranges Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5970995 Share on other sites More sharing options...
BloodBath Posted August 17, 2011 Author Share Posted August 17, 2011 lol. it always read 0.... guess what that means......... I guess that means no knock??? haha Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5972143 Share on other sites More sharing options...
BloodBath Posted August 17, 2011 Author Share Posted August 17, 2011 Sorry here in AUS we have AEM stinger and motorsport ecu's which are different from the US based AEM version 2.. in fact they are not even similar. I JUST NOTICED your location is USA or similar. The AEM Version 2 is an AWESOME ecu and we tune a fair few turbo hondas and some bigger hp supra stuff with them, YES it does have knock control and feedback engines but ive not had a play with one in a R33, it worked awesome on a turbo S2000 we did. I have a feeling it wont be compatible with the std RB25 sensors, but send Aem an enquiry as to whether ot not they are supported as its a great feature in the Version II. Aem Version II http://www.importpar...33rb26dett.html our Local AEM product range: http://www.engineman...products_id=107 Its kinda like comparing apples to oranges Yea it is definitely a very cool program. I have done all the tuning myself so far, just by data logging runs at the strip and third gear pulls. The weather is kinda shit right now. but I am very excited to see what this rb 25 has got in the future. Link to comment https://www.sau.com.au/forums/topic/373965-knock-sensor-test/#findComment-5972144 Share on other sites More sharing options...
