hey everyone
got a grey (sonic silver) gtt with altia bodykit right round.
looking at buying some koya drift teks black 18".
new to rims, dont know much about them but ive seen these and like the look of them, not over the top but original.
my aim is to find some cheap (in price) good looking rims in either chrome grey or matt black?
what does everyone think about the colour scheme and maybe other rims to reccomend??
im not sure about black rims, its either going to look great or cheap and tacky.
the drift teks blacks are a bit powdery so i think ill be same there.
suggestions???
jarrad
https://www.sau.com.au/forums/topic/373996-another-rims-post/
http://www.skylinesaustralia.com/forums/topic/146573-r34splease/page__view__findpost__p__5965040
here are my drift teks, they are gloss black not matt black. i think all of them are gloss black unless you respray them yourself
well at least now i know black drift teks look good on a white 34 :D
what sizing and offsets were they if you don't mind trying to figure out sizing for mine and yours looks exactly the way i want it though i still needa get coilovers :S getting there though
looks verry stormtrooper spec with the black wing i like it
thanks man
offset is 18x8.5 on the front and 18x9.5 on the rear +34 all round. Got them coz i wanted them to fit nice without sticking out of the guards.
  • 1 month later...
hey does anyone know if the drift teks are lighter compared to the stock wheels??
(i spose itll be hard for them to be lighter if there bigger, but there not like HEAPS heavy or anything are they??)
ive heard some wheels feel heavy and sluggish?
well i only have my 18x8.5 fronts atm but id say they would be about the same as the standard wheels dont have anything to weigh them. getting the rears and the other set on sat so i might be able to weigh them at some point hopefully by the weekend for ya
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
