Mmmm - I don't think that statement is accurate. My mum also has a 2005 RAV4 Cruiser 2.4L 4 speed auto. The n/a R34 sedan is quicker in all aspects in comparison to the RAV4.
Apparently the n/a R33 (i've never driven one) are the real slugs due to not having variable valve timing and variable intake length manifolds, but I'm just going from what I've been told.
Would I say the n/a R34 is fast - No
Does it handle/brake well - Yes.
I've said this in another post, n/a R34's performance is on par with a relativly late model 4 cylinder Camry.
Any commodore from VN onwards will leave you behind from 80km/h onwards (rolling acceleration).
Anything under 80km/h the n/a R34 will do reasonably well - you just got to keep the revs up.
Auto will make it slower. Phils mums might be manual which will make it a bit faster.
Just saying
Dont the N/A R33's have VCT?
Just saying
yeah they do.
otherwise it wouldnt only be R32 RB25DE heads that people rave on about for making 25/30s
Just saying
Yep - Good point, I forgot to take that into account.
But in saying that the RAV4 is heavier by around 150kg and has less power to start with, also the AWD system would sap quite alot of power.
A Rav4 cruiser and a R33 GTS both do 0-100 around 9-11 seconds. ie. Slow.
The point of my comment is that non turbo skylines are as slow as any normal passenger vehicle. Hell a stock GTST is quite slow by todays standards.
Of course.
I came out of a 1.4L cubic so my NA 34 feels pretty good.
On the other hand my brother in laws got a 350HP evo 6, so if i compare the cube to the 34 its fast or compare to the evo to the 34 its slow.
as someone said before P Plates are just the turbo lag of life.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
