You are dicking yourself in terms of performance and reliability.
Save your money and highflow the stock turbo to run the 12 instead of running dual maps so you can run some magical sauce only to blow the rear wheel off the turbo which might take your motor with it.
plus guys before you get all excited US fuel octane number is measured differently to ours (they quote an average of RON and MON we just quote RON which reads much higher than MON ratings). their 91 octane (AKI) fuel is somewhere around our 95RON fuel (not quite as good as our 98 RON but nor far off).
as for the OP, there is no set formula. you need to tune it for the new fuel and see how much boost and timing it will take before it either stops making more power or it knocks.
also why only 12psi? with no more boost you will struggle to get much more power. if it's only for drag runs, wind it up a bit. even just another 3psi of so will give some decent gain.
I've read that 12 psi is the most you want to run on the stock, ceramic turbo wheel. just not looking to hurt the engine. I need that bottom end to hold up to the GT35 when funding is available.
So far my best is a 13.30 @107. 12 psi 11.8ish afr's. this is with a 2.0 60'. I have some mickey thompson et streets now. shooting for a high 12's, maybe mid 12's on race gas.
If you are keeping the bottom end stock (i.e. not rebored and forged etc ) a GT3076 will give you all the power you can handle - 300 - 330kw. A GT35 is good for a lot more than the stock RB25 can cope with.
It's not the boost that kills the turbo, it's the excess shaft speed.
US fuel also contains more benzine and other products that make it more knock resistant for the same 'octane rating'.
Your going to need a fair bit more power to run consistant mid 12's from a 13... Id spend some time taking weight out of the thing first. Then a ethanol tune.
Or nitrous.
Cheers
Justin
I eventually plan on building up an engine for the car. the GT35 is just so I dont outgrow the turbo.
My car with me in it is under 3000 pounds, I should be able to shave a quarter second off the 60' foot time, I will be launching off of a two step at 5000. so a quarter second off the sixty has always been, and SHOULD be good for a half second off the big end. thats 12.80 without race gas.
I'm mainly just curious how much timing I can add for the race gas. Ive heard 6 degrees, 8 degrees??? also would I need to go to a hotter plug???
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
