This is a detail for Anthony as one of the cars I am sponsoring for the Skyline Nationals.
This car is a 90% dedicated track car as you will be able to tell from the battle scars! The purpose of this detail was to bring the car up to a respectable level where I will only need to give it a minor correction come nationals. So it is not a 100% correction.
Products used:
Bodwens Body Gel
Iron-X
Sonus Clay Bar
Menzerna Intensive Polish and Final Finish on Lake Country Pads
Wolfgang Souvereign Liquid Wax applied via DA on red pad
Some final shots
Sorry this wasn’t a big write up nor heaps of pictures but I was flat out as I had to do E3 R8 also this day with opti-guard! So stay tuned.
Regards
Mitch
https://www.sau.com.au/forums/topic/374074-anthonys-circuit-gtr-detail/
Just link with simply img tags
[img=  link   ]
Or just use the "button" to hyperlink them.
It keeps stuffing up because you keep changing the fonts, sizes and then not closing the HTML tags correctly. Some forums will tolerate it, ours does not.
If you stop trying to font/resize etc & just using the plain old standard text with IMG tags, it will work every time.
Plus it's easier to read the standard forum font.
[img=  link   ]
I dont change fonts or resize any thing....I paste all my links in word type up the thread then copy and paste it in each forum. so Im confused, but in saying that Im not the most computer literate guy.
On a side note with the forester thread the first one stuffed up I re did it exactly the same literally copy from word and paste again and it worked so it cant have anything to do with my links and post, it must have to do with your system. Maybe its picky some times?
Mitch, thanks for the detail the car looks awesome :thumbsup:
On a side note would you recommend a microfibre cloth for removing any dust or is the best way a quick water spray?
Yea Anthony just a gentle wipe over with a microfibre.
There's your problem. Type it up in notepad (or another plain text editor) instead. Word puts in it's own html formatting which, of course, just causes problems.
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
