Hi guys,
I just got myself an R33 - and I am loving it!!
I want to install a pair of rear speakers, but am a little confused!
I have attached 2 photos with what the situation looks like back there and there seems to be these 2 black brackets, that (to me) don't appear to be doing anything?
Can you guys let me know what they are for? Could I just remove them to install my speakers?
What else would I need to do to put a pair for 6 inch speakers there?
Thanks!
dex
https://www.sau.com.au/forums/topic/374093-r33-rear-speaker-install-help/
Hi guys,
Thanks!
dex
Just found out...child restraints or something....grr..ok need to remove them and everything to get some speakers in there :(
  • 1 month later...
I'm having the same issue, I would leave them in because it is technically a roadworthy issue. I found out today that not many aftermarket speakers will fit under there......But if you mount the speakers from the boot and screw them in from the boot they will have no clearance issues with child restraints.......what a prick of a place to put them ey......
your ADR rules say 3 baby bolts, funny how in the fark would you fit 3 kids in that car with prams and car seats.. idiot rules even 1 kid would be a tight fit. with my seat all the way back , they would pull my hair out while driving..lol
but if your clever you can mod it to look like they are funtional in a much better spot minus the bracket . just return it to the way it was if you sell it. so you dont get hit with a lawsuit from a child death . disclaimer take this path at your own risk, not responsible for defects or injury from someone using it
funny enough the r31 built in oz had holes for bolts but not the attachment points installed. pure proof how bad they fark with jap imports on compliance.
the monekys that did my car killed my alpine DD speakers and grills with the brackets. on compliance. and then didnt bother hooking the speakers back up since they crushed the cones sideways with brackets. muppets had no farking idea.!!!! alpines went to the bin
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
