R33 Rear Speaker Install Help
That bit at least you can fit by drilling a couple of clearance holes in the sump webbing to get a socket in there
Safety network should be dedicated, duplicated, disparate physical route. If it's not that, it was never good enough, even with maintenance.
You also have to pull the box out to take the sump off an rb26 because a few of the bolts are inside the belhousing. just put something long and metal through the sump plug hole till it attaches to it and take it out through the hole the real lesson to learnt here for everyone is don’t use cheap parts because they end up costing more in the long run
Probably the voltage dropping towards 11.1V, below a potential minimum requirement for the voltage regulator circuit and/or the capacitors inside are undersized to maintain a constant voltage. I'm no electrical engineer but that's at a high level guess. -
That is a pretty poor reflection on a well regarded ECU...surely a clean 5v supply for the sensors regardless of ECU voltage is #1 requirement
